MIDI Expression 2.9.3 BETA is available
jlmh007
Re: MIDI Expression 2.9.3 BETA is available
Post by jlmh007 »
Thank you Rob for your fast replies, about the messages, as longs as the two CCs 00 and 32 and PC come in the right order No problem, the volume command can be sent last. The bug I think I found is the one I showed in the video, the values don't stay, The only way I made them work yesterday was, closing the app after changing the values in each transformer. That was in the mac app, in the iOS app the values stay after changing on the screen but were not applied to the pedal. Please help me check when you have time!
Gracias !
Luis Moreno :)
So this works right?
07-03-2024, 11-36-28.png (97.16 KiB) Viewed 1503 times
jlmh007
Post by jlmh007 »
Hi Rob, thank you, yes, that is exactly what i need to send, that order will work good.
:D
I'll post build 18 in a few hours.
I posted build 18.
  • Fixed transformer settings bug.
  • MIDI monitor now has a configurable filter.
  • Control Application will now properly minimize when clicking on its icon in the taskbar (Windows).
jlmh007 wrote:
Wed Jul 03, 2024 4:20 am
:D
Here's how you should setup the footswitch. I assume you'll be able to figure out the transformer bits on your own
07-03-2024, 14-52-58.png (108.22 KiB) Viewed 1501 times
jlmh007
Post by jlmh007 »
Thank you Rob for your time and effort, I'll download and apply the firmware now.
I am gonna follow your guide for the setup.
Appreciate it !
jlmh007
Post by jlmh007 »
I just upgraded and tested it, it works very well now. The four messages are sent with one switch press.
Just something I was not aware is that transformers work globally, I thought each switch could have their own transformers. Or I am missing something? is there a way to have trasformers for each switch ?
Thank you once more for your fast responses Rob
The transformers work globally and there is currently no way to add extra on a per / switch basis.
jlmh007
Post by jlmh007 »
Thank you Rob for your response, I am gonna try to combine a midi solutions dual footswitch controller to manage a STOP message and another 4 mseeages in one switch I need.
Would be nice to be able to send more messages per switch and transport and sysx messages as well with the IO. for me is ok for now, I can combine boxes.
Hope you could implement those in the future !
Thank you for your help Rob !
