eDRUMin 1.6.2 BETA
Re: eDRUMin 1.6.2 BETA
Well if pads are assigned a kit piece identifier, it would pretty easy to have any number of hihats, or two seperate pads triggering the same notes.
As for the the upgrading progress, I'll just have to leave current system in place. An input could be switched between using maps and using the current notes/note banks.
1.7 request:
An advanced option for a single switch input to perform a notebank change AND send a control message.
Use case, snare throw off - change snare note to snares off instrument AND mute snare bleed channel in SD3.
Thanks.
Hey Rob,
Is there any chance that 1.7 could include Positional Sensing for Yamaha TCS pads? The new DTX-Pro module implements PS for both mesh and their TCS pads.
Thanks!
Good chance.
Tue Dec 07, 2021 3:01 am
Good chance.
Great to hear!
Observation. After playing a rimshot and I follow up with some ghost notes I intermittently get a single sidestick. I’ve tried to keep an eye on the screen to see what is going on, but I can’t seem to see it. I do the rimshot at the seven o’clock position and then I play the ghost notes on the edge at the 3 o’clock position. Seems to be a recent occurrence.
I noticed something off too. I'll try to take a look next week.
Sun Dec 12, 2021 9:45 am
It may be nothing, but it seems like it happens most often during a grove. Not just when I’m playing the snare alone. I first noticed it occurring often when my right hand is on the ride, and my left foot is doing 1/8 notes on HH pedal. I first picked up on it after you fixed the issue I had before with my Tom rim playing a head articulation instead of a rim articulation. May be completely anecdotal, but that is when I first noticed it. Then I spent a couple days proving to myself it wasn’t me.
It's a strange one. I'm hearing it on my snare. But if the control application is open, auto-select is off, and the snare is selected, the issue is gone.
Tue Dec 14, 2021 1:07 am
Yes exactly. I noticed the same thing so I could never take a screenshot of what was happening.
