eDRUMin 1.2 BETA is now available
vandroiy
Re: eDRUMin 1.2 BETA is now available
Post by vandroiy »
Rob wrote:Changes in Build 7
  • A possible fix for reports of unintentional choking on cymbals
  • Numerous UI improvements to reduce CPU usage.
Will try that tonight!
Changes in Build 8
  • Fixed flashing LED when input 2 is connected
  • Includes firmware for ED10
  • Fixed macOS Auto-Select state was not properly sent to the device issue.
vandroiy
Post by vandroiy »
Cymbal choking ist gone now! Works for me
Finally upgraded to 1.2.0.8 and now my ride is getting nothing but bell. No bow or edge. I have it set as a 3 zone Roland. It was working fine with the last 1.1 release which I think was 32 or 33 maybe. The cymbal is a Jobeky 3 zone ride. 2 inputs.
I'll check it out.
No that didn't do much. I have some bow but now it is all over the place. And still no edge.
Hmm... I need to think about it for a bit. For the record, I tested here with my Roland rides and there were no issues.
Mylo, do you know how to capture data from the device?
Can you record five bow hits, then 5 edge hits, and lastly 5 bell hits?
Also, can you double check that your 'BOW / BELL' cable is plugged in all the way on both ends?
