Looking at the Superior Drummer mapping, it only shows 2 rack toms instead of 3. Is that something that will be updated?
Any Tips For Magnatrack Triggers with L80 Cymbals
Re: Any Tips For Magnatrack Triggers with L80 Cymbals
- Screen Shot 2022-09-03 at 5.41.37 PM.png (1.28 MiB) Viewed 492 times
- Screen Shot 2022-09-03 at 5.41.28 PM.png (143.63 KiB) Viewed 492 times
There are more rack toms on page 2, but you might need to edit the MIDI they send. That's probably something that should be set up out of the box. I'll double check later.
UPDATE: I checked, the red rack tom from page 2 is already properly setup to trigger the 3rd rack tom in SD3.
