eDRUMin version 2 BETA
Re: eDRUMin version 2 BETA
monospace,
I'm really at a lose here. I've rebuild build 17 with one tiny change. I've made it so that the 'reset input' icon is accessible overtop of the "Roland 3-Zone Cymbal Bell input" screen. It's a hack, but hopefully gets you back up and running. I've updated the download. Use the same link as before.
That doesn't seem to work, button remains inaccessible.
I don't think you app is properly updating. I suspect you are still running a much older version.
I'm not exactly sure what happened with that last build, but you're right. The reset wasn't accessible. Sorry for wasting your time. Here's build 18.
eDRUMin_Control_OSX_2.0.1.8.zip
Fri Jul 29, 2022 11:48 pm
No problem. This finally worked. I was able to reset the Bell input. Been switching back and forth between 2 and 3 zone cymbals on those inputs a couple of times, and it's not getting stuck anymore.
Fri Jul 29, 2022 9:57 pm
Well, not sure if it's related, but I am still getting the "You Have Unsaved Changes" screen every time I attempt to update the ED4, though not with the ED10 which is where the ride cymbal is plugged into. I've not been reporting it because it's a minor annoyance, and the ED4 seems to take the update anyway. The about screen on both devices indicates I am on the latest and greatest Beta.
Well I'm relieved that that is sorted out. It was probably the result of some leftover settings from earlier BETAs. As for the the "You have unsaved changes", you probably don't have 'auto save' turned on for your ED4. And if you are using a pedal to change banks, the settings for the device will be dirty and so it will warn you.
Sat Jul 30, 2022 1:40 am
I am using a switch to change banks on the ED4, but Autosave is also enabled. I'll see what happens with the next firmware update.
Dadwrshpdrum wrote:
Mon Apr 25, 2022 2:29 am
Mon Apr 25, 2022 2:24 am
Could be a bug. On ED4 lines connecting to inputs indicate that the first one is set to 3-Zone Roland or Metal cymbal pad type.
So I purchased and just received a new ED4R3. I really like it BTW. Very cool with the metal case. Originally that ED4R2 I took a screenshot of had two HH cymbals as the inputs now linked by a redline. I did not reset the inputs. I just loaded user preset I had for the rubber cymbals I replaced the HH cymbals with. After loading the presets I changed from HH cymbal to drum kit pieces then the desired drum kit piece. (I moved the HH cymbals to the ED4R3 since that unit has the slightly improved pedal input).
BTW - V2 made changing my set up from ED10 and an ED4 to ED10 and ED4 quantity 2 super easy. I moved a bunch of inputs around and it was very easy to remap stuff.
Latest beta release seemed to have helped this problem on ED4 in which inputs three and four had a red line linking them even though they were not a 3 zone Roland cymbal nor metal cymbal. The redline is still there until I select one of the problem inputs manually then line disappears. The redline will reappear if I select another input (like 1 or 2) then select a different eDRUMin then I reselect the ed4.
Dadwrshpdrum wrote:
Mon Aug 01, 2022 4:39 am
Latest beta release seemed to have helped this problem on ED4 in which inputs three and four had a red line linking them even though they were not a 3 zone Roland cymbal nor metal cymbal. The redline is still there until I select one of the affected inputs manually then line disappears. The redline will reappear if I select another input (like 1 or 2) then select a different eDRUMin then I reselect the ed4.
Bug report, latest build.
My lemon 18 ride now only triggers bell sounds when striking the bow. Setup as a Roland 3-zone ride. Inputs 9+10 eDRUMin r1.
Only fix is to unplug the separate bell cable! tbh, it's always been a little over sensitive, but now unusable.
Personally I would like a slider that allows me to tweak the bell sensitivity - would this be possible, please?
