The Windows version is working for me. When I start the app all the notes are numbers now.Dadwrshpdrum wrote:First, this is major improvement and is very helpful. However, I don’t know what “saved between sessions” means. I changed from notes to number, and I went from every pad, pedal and note bank. Numbers remained the default everywhere, very nice. I assumed a session was closing the app and reopening. This did not work. Defaulted back to notes. However, I don’t think that is an issue for my own use case using a laptop.Rob wrote:Changes in build 29
- Right-Clicking a note control will toggle notes/numbers for all note controls and setting is saved between sessions
Update: I've been running a brand new 20ft cable since Tuesday without a single random crash. So it could have been just a faulty cable (in combination with the cable length.) I'll keep monitoring it and report back if anything changes, but so far so good, knock on wood.
So I just updated to Build 29 and I'm no longer seeing my ED4 in the Control App. Updated the ED10 first and was going to do the ED4 next (without replugging anything) but the device was no longer visible at top right. Connected to it directly, no problem, update went through.Rob wrote:Changes in build 29
Both devices work fine after the update, I can play all my pads, it's just that the ED4 is no longer directly accessible in the Control App.
(I used the new cable mentioned in my previous post for the update, but bypassing the hub. ED4 is connected to the ED10 with the same cable I've been using for months.)
I'll check it out.
When I sat down to play today my PD-125BK presets on input 1 were wrong. Must have happened during a recent firmware update. Hold jumped to 22.9 ms and x-stick went to 32.0. Rolls sound terrible and the rim was too loud. So it is not a display issue but the values were changed. Values should have been 5.7 ms and 4.9 respectively. Now that I reloaded my saved preset it looks like scan and thresh was off too. Trigger curve was not changed and I don’t think hotspot suppress was wrong. Same thing with rimshot, it looked like that was unchanged.Rob wrote:Changes in build 29PC
- Right-Clicking a note control will toggle notes/numbers for all note controls and setting is saved between sessions.
- Adjusting the curve for an articulation will automatically set it to 'independent'.
- Improved behavior of tool tips for knobs and faders.
- Adjusted default settings for hihats.
https://www.audiofront.net/eDRUMin_Cont ... 4.0.29.zip
macOS
Crash report for 1.4.0.29. I was setting up a new note bank for a pad, and had just finished the head and SS notes. As soon as I left clicked RS the app crashed. When I reopened the app and went back to the rimshot note I was adjusting I think the note randomly changed to 19? Before it crashed I never got a chance to type anything in, and I don't believe it was at 19 to start. I set up a new note bank (#3) for one snare, and 5 tom pads. It only crashed that one time on the 3rd pad (out of 6).
- crash report 1.4.0.29.zip
- (21.26 KiB) Downloaded 118 times
I think I've seen an issue in similar circumstances before. Thank you. I'll investigate.
I downgraded back to Build 26 and both devices are showing again.monospace wrote:So I just updated to Build 29 and I'm no longer seeing my ED4 in the Control App.
I'll look into it soon. Thanks for the heads up.
Working fine on Windows, but indeed broken on macOS. Likely related to downgrading from Big Sur to Catalina. I'll try to find some time today to sort this out.
