For me... the less I have to think about the better. The ultimate UI/UX is an app that doesn’t need documentation.
I like where you’re going with that Mode label.
I deactivated it and I get clean splashes and fast tempo chicks without any artifacts so for me you can get rid of itDoes anyone use / want the 'always send on closed' feature? If I got rid of that, I could declutter things a lot.
You can't disable this behaviour in SD3 unfortunately. The previous 'fix' was just to unload the pedal open articulation, however now with the fast stepping fix, I don't get any splash artifacts any more. If they're still happening, (with the check box ticked) maybe reset your HH CC mapping to default in SD3?monospace wrote:Didn't know that. Do you know if that can be disabled, and how, so I can compare side by side?MWJT42 wrote: Are you using SD3? That also has its own 'make a splash sound based on CC events' (rather than MIDI note) built in.
However, it's crap (overly sensitive during fast HH foot taps) hence all the work Rob's put into 1.3.
- dsteinschneider
I don't want or use it.Does anyone use / want the 'always send on closed' feature? If I got rid of that, I could declutter things a lot.
Thanks,
Doug
Haven't found a need or use for it either.
The only reason I added the "Always Send on Closed" feature was because of a comment on vdrums:
I'm pretty sure this user was referring to slowly closing the pedal and the 2Box module not silencing a ringing open hihat sound. Is this an issue on any other modules? I'll try to do some research.I tried using it on a 2Box drumit three and it worked nice, but when I closed the HiHat the sound for "Pedal closed" was still sounding on after I closed it, which did not happen with the Hats plugged into the 2box.
Here's build 20. I've left the 'always send closed' option in there for now. I do remember a couple people wanting it.
Changes in build 20
Changes in build 20
- Cleaned up the hihat layout.
- Renamed 'stand' to 'impact'
- Advanced options are now disabled if the pedal / cymbals are not linked.
- Fixed numeric value display for knobs (broken in build 18).
- Updated the manual.
Hello Rob,
since build 1.3.015 Hi Hat Splash is not working for me.
With version 14 the splash is easy to archieve
I have Roland Vh-10 Hihat controller, Edrumin 4.
any ideas, settings that should work?
Regards, Peter
Regards, Peter
Checkout version .20pwohlfah wrote:Hello Rob,
Regards, Peter
Quite a few changes since .15
I like the changes in 20
- - The pedal setup is a lot cleaner. Went with the radio button for Mode. Nice.
- “Impact” works well. Lines up nicely with the text in the manual.
- Scaler numbers are back. Now I can see what I’m doing again.
