Changes in build 23
  • Fixed adjusting the right side of the calibration range turns 'sense' on.
  • Yamaha hihats can now be properly calibrated.
PC
https://www.audiofront.net/eDRUMin_Cont ... 4.0.23.zip
macOS
Can anyone share a pic the their calibration range for the ATV Artist Hihat?
Build 23:
Control App crashed while installing firmware, rendering both my devices unresponsive. Power-cycling made no difference. Cannot downgrade because devices are no longer recognized.
Crash report attached.
edrumin_crashreport_021921.zip
(16.42 KiB) Downloaded 123 times
Edit: ED4 still works, since the app crashed on applying the update to the ED10.
Code: Select all
Thread 9 Crashed:
0   com.apple.framework.IOKit     	0x00007fff35c29417 IOHIDDeviceSetReport + 8
Crashed in Apple's code. Not entirely sure why. Any chance the eDRUMin 10 was connected to a USB hub? Please send an email to support at audiofront dot net and I will help you recover the device.
For those following along: my device has been successfully restored with Rob’s assistance.
monospace wrote:For those following along: my device has been successfully restored with Rob’s assistance.
What version of software are you running now after the restore?
Here's running build 24. He was updating using a USB hub. While I can't be sure that using the hub was the issue, I have seen problems when using hubs in the past and that's why I have that warning screen.
One small feature of build 24 is that it will auto calibrate hihat pedals that haven't been calibrated yet. VH-10, VH-13, FD-8, HD-1, HH65 will all the properly calibrated out of the box.
Changes in build 24
  • Uncalibrated hihat pedals will be auto-calibrated.
  • Changes to allow restoring a bricked device.
PC
https://www.audiofront.net/eDRUMin_Cont ... 4.0.24.zip
macOS
Unintended consequence of getting your device bricked... you get to start from scratch. And that's where eDRUMin shines. I had some presets saved, but I decided to take the opportunity to start anew, and for the most part, it took me 5 minutes per trigger at most, to get everything dialed in right where I wanted.
Rob wrote:Here's running build 24. He was updating using a USB hub. While I can't be sure that using the hub was the issue, I have seen problems when using hubs in the past and that's why I have that warning screen.
Thanks. I updated to latest macOS version with no problem. I thought this beta software was good and stable before. You continue to make a lot of nice enhancements. Thanks!
Changes in build 26
  • MIDI from USB MIDI in will now be forwarded to MIDI out / USB Host port.
PC
https://www.audiofront.net/eDRUMin_Cont ... 4.0.26.zip
macOS
