Yamaha XP Pads (Silicon) Supported? Only TP Listed in Manual
TOP
Re: Yamaha XP Pads (Silicon) Supported? Only TP Listed in Manual
Post by TOP »
Thanks for the informations Rob, anyway , I'm very grateful because at first glance I saw that the Lemon snare pads was written to support positional sensing in the unnoficiall supported pads thread.
TOP
Post by TOP »
Sun Sep 10, 2023 1:19 am
Just to be clear, all Yamaha 3zone.pads will trigger 3 zones with an eDRUMin. You'll get center, sidestick, and rimshot. Positional sensing, where you get center, off-center, and edge is not supported in Yamaha snare pads.
I am aware that Yamaha has designed some of its pads to support positional sensing (xp125t-m for example). I suspect eDRUMin 's positional sensing work work fine with them, but I don't have any of those pads to test with.
Hi Rob... why cant i get rimshot for xp80? if i use xp80 from preset mgr i only got center and SS.... am i missng something?Thanks for ur help
Sly
Post by Sly »
Maybe a bug in the firmware, here is what we read today on the BETA3 update page : "Posted build 8 to fix an issue with Yamaha 3-zone pads"
Try this last build
Yes, I just fixed the issue today. The bug only affects ED8 devices. My apologies.
TOP
Post by TOP »
great Rob, no worries... are they ready now? where can i download? thanks for ur engagement, very appreciate
