My new edrumin thread
OftheSeven
Re: My new edrumin thread
Post by OftheSeven »
Rob wrote:I do plan to, but I want to wait until I'm sure my memory structures are set in stone. I don't want to implement that feature too early and then end up having to do a lot of work to update stored presets in the future.
Want to revisit the subject of 'saving' settings. Could it save my user settings to a file on the host computer to be re-called as needed?
I don't think the hardware would need to store anything.
I have to make hi-hat changes when using SSD5 vs SD3 and having a saved file would be helpful.
I also have another drummer who uses my kit and hits much harder than I do. Having a saved file with his velocity curves would be awesome.
Thanks
Ya, it's probably something I can do soon.
+1 on saving setups :D
Yep... probably the biggest feature I want. That and hot spot suppression on cymbals. :D
