eDRUMin version 2.3.2 BETA now available
Re: eDRUMin version 2.3.2 BETA now available
I posted build 7. This version has a lot of changes under the hood and so downgrading from this version will result if you device being factory reset.
Changes in build 7
  • Changed how switch type pedals are handled to improve flexibility and make them more intuitive.
  • Improved (fixed) the resolution of the decay control.
  • Updated the user manual.
10-31-2024, 13-57-31.png (163.2 KiB) Viewed 1865 times
edrumbarry
Post by edrumbarry »
Hey Rob - First, I just want to say thanks for the awesome product and the update is great. I have had a lot of success
One thing I am noticing is that the hi-hat pedal settings aren't saving. I will set up the travel, splash, change to stand, and just the dials. once I click another bad it all goes back to minimum settings
Thanks again for the update and the work!
I only tested very quickly and couldn't reproduce the issue. What eDRUMin hardware are you using?
Abeille
Post by Abeille »
hello!
did you fixed the C-2 bug? (no note OFF message)
please let us know!!
all the best!
I'll post a new build with the fix today.
Changes in build 12
  • Fixed Note off not being sent if input note is set to c-2 (0).
  • Disabling the compatibility check will now clear the compatibility issue on any pads (won't need to unplug / replug or power cycle the unit.
  • Fixed issue setting channel on second button of footswitch / rotary encoder.
  • Improved rotary encoder support.
  • Various bug fixes.
edrumbarry wrote:
Thu Nov 07, 2024 2:49 am
One thing I am noticing is that the hi-hat pedal settings aren't saving. I will set up the travel, splash, change to stand, and just the dials. once I click another bad it all goes back to minimum settings.
Fixed in build 15.
edrumbarry
Thanks and sorry for the delay in my response. I will download and try it out!
Posted build 17
  • Fixed broken factory reset since build 7.
  • Fixed sending presets from iOS control application.
  • Fixed a firmware issue that would crash the hardware when sending presets from iOS.
  • Pedal editor opens more smoothly now, especially on iOS.
pumpkinking
Post by pumpkinking »
Hi all. Just upgraded to 2.3.2.15 last night (from a pre-2.3 release), and now note bank changes with a sustain pedal are no longer working. The pedal device screen shows the bank incrementing, but none of the trigger note banks are incrementing. I have tried resetting the pedal setup and reconfiguring it, but same behavior. Has there been a change to this? Or has the functionality broken somewhere in this release branch?
Thanks!
