EDrumin 8 + vh-13 + DTX pro module issues
Re: EDrumin 8 + vh-13 + DTX pro module issues
Hi Marcos,
There shouldn't be any lag. The only thing I can think of that might be causing an issue is if the eDRUMin is sending too much MIDI such that the DTX can't process it fast enough. Maybe try enabling the 'only send CC with hit' option.
12-23-2023, 06-53-13.png (84.56 KiB) Viewed 5172 times
You device will need to be in advanced more to see that option.
Enable Advanced Mode
xcomp666
Post by xcomp666 »
Make sense, because it is happening when I am playing something with more groove and noites . Playing rock/ metal stuff doesn’t happene quite often , I will try it tomorrow. . Thanks
