Center Flam Triggers Off Center Hit
AKA Wayne
Re: Center Flam Triggers Off Center Hit
Post by AKA Wayne »
Ok. I watched the video and shortened my hold time while making my decay more aggressive. I tested with some flamadiddles and I wasn't getting any off center. Also PS seemed reliable, not sure of it's more reliable or less than before because it was very good to begin with. On first impression I guess it might be more consistent in the center vs off center. I was able to make the center zone smaller in SD3 which supports the fact that it is a bit more precise. I'll have to really play around more to be sure. Thanks for the help Rob! I think I'm getting somewhere.
Screen Shot 2023-12-16 at 9.09.26 AM.png (716.04 KiB) Viewed 4666 times
That looks much better, but I think you'll run into issues with your hold time so short, especially with hard hits right next to the edge of the pad.
AKA Wayne
Post by AKA Wayne »
Thanks for the feedback Rob.
nemo
Post by nemo »
Sat Dec 16, 2023 9:20 am
Keep your hold where it is, and make your decay more aggressive. The way it is now, the envelope can't return to zero quick enough to pick up the positional information for the second hit.
Thank you Rob, it helped!
