Planning a new eDRUMin family member
Re: Planning a new eDRUMin family member
I should have something set up in a couple of weeks.
bpjacobsen
Post by bpjacobsen »
Hey Rob, can this be preordered or no? IMO I do think first come first serve is the fair way to go. This gives everyone a fair shot at getting it. I need two for my setup. Still looking at mid Sept?
kevinbeckman1983
Post by kevinbeckman1983 »
For me, the 8th input is vital, I would've got the eDrumin10 if able. Anyways, I like the option of 4 toms and need a splash and effects cymbal (beyond crashes, hats and ride). You may want to look into a separate product or peripheral for those that need a midi in on their edrumin setup. Couldn't you use the USB host port, for a separate midi to USB adapter (to add midi in function to any edrumin?)? I'm no expert, but that seems it may be more doable, while adding an extra /8th trs trigger input, via the USB host port may not be as simple or cheap to do? That's my 2 cents ;)
