eDRUMin 1.6 BETA
Re: eDRUMin 1.6 BETA
Changes in Build 1
  • Two separate PS algorithms for cymbals (1) For Roland and (2) For Yamaha and Lemon 18" Ride
  • Fixed Bell Sense issue with CY-13 algorithm and improved performance in general.
https://www.audiofront.net/eDRUMin_Cont ... .6.0.1.zip
Great work, it works great on my CY-15RMG,I used the bow tip and bow shank in the core library and the bow tip 1 and bow tip 2 in death. I uploaded a video: https://youtu.be/-2nKYUcQ_hI
Bell sense should be much improved too, especially using the shaft of the stick to hit the bell.
Yes, hitting it with the shank is more reliable, but I’m still getting bell on the upper part of the bow with light or hard hits
Ya...it's really hard to find the perfect transition point with wave analysis. I'll look at it again in a few days to see if there's something else I do to get a better transition point.
Ok thanks, let’s hope you find it. A couple of things after updating to 1.6 my edrumin10 r2: the device wasn’t recognized by my mac so I reset it and still nothing, so I unplugged all the cables and it recognized it, I configured everything again and turn it off and then at night again wasn’t recognized so this time I unplugged just the pedal cable, power cycled it and plug it in and then it was recognized, plug the pedal cable but it was reset so I had to calibrate it again, unplugged it, went to sleep and this morning again, device not recognized, pedal reset, so I think it’s the pedal input with the drone controller that confuses the edrumin. When I plug it in it triggers a crash sound without me doing anything.
I tried to save a pedal preset for it but it won’t save it
lalo wrote:
Fri Aug 06, 2021 10:07 am
I assume that was with build 0. Still happening with build 1?
I just read your post about the Drone. I imagine you would have had that issue with version 1.5 as well? I suspect the problem is that it's a 5V powered unit? Applying 5V to the pedal input would certainly cause problems. Does the ED10 work properly of you don't plug in the Drone? Why not just power the Drone from the 3.3V supplied by the pedal jack?
Yes it happens with 1.5 and 1.6 0 and 1. Yeah I’m using it with a 5v adaptor, I tried using it only with the pedal input, it didn’t work, so I just have to remember to unplug the pedal cable before plugging it in, maybe I’m going to buy an external adaptor so the edrumin is always on
Edit:
Ok duh I realized even with a external adapter I still need to plug the edrumin to the usb of my mac for midi…
If you have a multimeter, I would like to know what voltage there is between the tip and ground of the cable when the drone hihat is powered, but not connected to the eDRUMin. That would allow me to do some tests here to see if there's a workaround.
