Foot Piano
Re: Foot Piano
You have the pedal setup incorrectly. It should be auto-detected if 'Sense' is on and polarity is set to 'Auto', but if you really want to set it up manually (not recommended), it should look like this: Notice that the polarity is set to 'Reveresed'
Re: Foot Piano
For the record, I'll have to try the hall effect thing again on my AGO pedal board... I was studying this picture i took yesterday and totally just now realized I had the ME plugged into the harness instead of the hall effect chip... Dont know how I botched that... I will try the ME again tomorrow on the daughter board leads... I see no reason why it shouldnt work now that i see my obvious...
Re: Foot Piano
Ok cool, I will try that polarity with FC3A, (or just stick with the auto-sense)... after clicking all the bells and whistles I'm sure everything is incorrect...
not to confuse things with all my posts, i pretty much got two projects, array of FC3A/Sustains for a pedalboard, or a salvaged AGO Pedal board... I'm using your ME to help make decisions in which direction would be best...
Appreciate your tips
Re: Foot Piano
Here's version 2.8.6.10. I changed it so you have to release the pedal a bit further before the note off message.
Windows
www.audiofront.net/ME_Control_PC_1.8.6.10.zip
macOS
www.audiofront.net/ME_Control_OSX_1.8.6.10.zip
Windows
macOS
Re: Foot Piano
that update is working much better... seem like the off note doesnt send until it gets under 88 to 85 around there, which is providing enough room so i dont have to mash foot the entire time... with the Sense on and polarity auto, I can consitently hit a low, medium, high velocity... so over all the FC3A is working much better now... thanks for the update Rob
Re: Foot Piano
I had sent a email regarding your order of Quattros. Can you check the email and reply back to me?
Re: Foot Piano
i've checked my spam and inboxes, i'm not seeing what email you're mentioning...
Re: Foot Piano
i found it as a reply to some other... willl respond, thank
Re: Foot Piano
Dang dude! Took some doing but I fianlly built my Fiano "foot piano"
Man, you really got a awesome MIDI device...
I look forward to adding more in the future for controlling these things...
As it stand, I seen in the docs (and experienced) only four can connect at time for programming, but I managed...
I also had an issue where somtimes a few ME's would stop working, but I figured it the USB hub wasnt providing enough power, so I added two USB hubs... cant wait to try this thing out again this weekend... was alot of fun to play! Thanks again for such an awesome product Rob
Re: Foot Piano
close look at ME's installed
- Fiano4.png (1.31 MiB) Viewed 2070 times
- Fiano3.png (1.35 MiB) Viewed 2070 times
