eDRUMin version 2 BETA
Re: eDRUMin version 2 BETA
I've seen that too. I'll keep an eye out.
Luckymethod
Post by Luckymethod »
Thu May 19, 2022 12:00 am
I made a video because I'm going crazy. Can you tell me if you spot anything wrong in what I'm doing or I'm just experiencing a bug?
https://photos.app.goo.gl/L9F2TDoZznzsPwGi8
Luckymethod
I would like to offer some constructive feedback about the UI: it's VERY hard to figure out what's going on, and what the various templates are supposed to do. I get the desire to go for a compact UI but maybe it's TOO compact. I'm happy to mock up a couple of ideas to solve some of the key issues, I don't think a huge overhaul is necessary but there's just something that doesn't work in the current layout. Let me know if you're open to that.
I tested here. There's definitely a bug.
Fixed for the next build. The bug only affect hihat pedals setup to use 'Customs Notes'. A workaround is to setup your note assignments in the drum map and change your hihat pedal to 'Hihat Kit Piece'.
Luckymethod wrote:
Thu May 19, 2022 5:43 am
Please do. I would love to see your ideas. BTW, you know you can scaler the UI to whatever size you want by dragging on the edges right?
Luckymethod
Thu May 19, 2022 8:49 am
I think there's a little more to that cause the issue was happening with selecting hi hat too. I changed the mapping and made one specifically for Melodics but it didn't seem to help all that much, I'm still getting the hat stuck on a specific note and the mapping doesn't seem to take effect. I can make another video to show you that.
yes, that I know but the problem I'm referring is that things "stack on top of other things" in ways that I find disrupts my ability to keep track of what I'm editing. It doesn't have to do with the size of the window but with the layout. Before I sketch anything I'll take another video to show you where I find difficulties.
Changes in build 3
  • Fixed an issue with 'Hihat Levels' mode when set to use custom notes.
  • Cosmetic improvements
Luckymethod
Thu May 19, 2022 9:50 pm
Changes in build 3
things got a little better. Custom notes now works fine, but the drum map is still not working at all. I made another video to show you:
https://photos.app.goo.gl/JXH45TSAZ3m7b6JG8
let me know if it's user error but I doubt it.
Luckymethod
Luckymethod wrote:
Fri May 20, 2022 2:04 am
Changes in build 3
It just crashed on me:
Code: Select all
Translated Report (Full Report Below)
Process:               eDRUMin [5488]
Path:                  /Applications/eDRUMin.app/Contents/MacOS/eDRUMin
Identifier:            com.audiofront.eDRUMin
Version:               2.0.1 (16)
Code Type:             X86-64 (Native)
Parent Process:        launchd [1]
User ID:               501
Date/Time:             2022-05-19 19:06:15.7152 -0700
OS Version:            macOS 12.3.1 (21E258)
Report Version:        12
Bridge OS Version:     6.4 (19P4243)
Anonymous UUID:        711093E2-26D4-FCA5-0CE3-BF0C643ED235
Sleep/Wake UUID:       8CEC27A9-5079-4416-B633-4881E389BA28
Time Awake Since Boot: 17000 seconds
Time Since Wake:       973 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
Exception Codes:       0x0000000000000001, 0x0000000000000000
Exception Note:        EXC_CORPSE_NOTIFY
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [5488]
VM Region Info: 0 is not in any region.  Bytes before following region: 4401369088
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      UNUSED SPACE AT START
      __TEXT                      106579000-106891000    [ 3168K] r-x/r-x SM=COW  ...MacOS/eDRUMin
Thread 0 Crashed::  Dispatch queue: com.apple.main-thread
0   ???                           	               0x0 ???
1   eDRUMin                       	       0x10667ae9d AFTileSelector::~AFTileSelector() + 83
2   eDRUMin                       	       0x10667ad65 AFTileSelector::~AFTileSelector() + 21
3   eDRUMin                       	       0x1065ed106 VSTGUI::CViewContainer::removeAll(bool) + 242
4   eDRUMin                       	       0x1065e9031 VSTGUI::CViewContainer::beforeDelete() + 99
5   eDRUMin                       	       0x1065dadfb VSTGUI::ReferenceCounted<int>::forget() + 27
6   eDRUMin                       	       0x1065fe0fa std::__1::list<VSTGUI::SharedPointer<VSTGUI::CView>, std::__1::allocator<VSTGUI::SharedPointer<VSTGUI::CView> > >::erase(std::__1::__list_const_iterator<VSTGUI::SharedPointer<VSTGUI::CView>, void*>) + 46
7   eDRUMin                       	       0x1065ecffe VSTGUI::CViewContainer::removeView(VSTGUI::CView*, bool) + 314
8   eDRUMin                       	       0x10670233d MED_Layout::showLoadFromMap(bool) + 573
9   eDRUMin                       	       0x10657cf33 AFControl::valueChanged() + 75
10  eDRUMin                       	       0x106587e45 AFButton::onMouseDown(VSTGUI::CPoint&, VSTGUI::CButtonState const&) + 759
11  eDRUMin                       	       0x1065e055d VSTGUI::CViewContainer::onMouseDown(VSTGUI::CPoint&, VSTGUI::CButtonState const&) + 537
12  eDRUMin                       	       0x1065e055d VSTGUI::CViewContainer::onMouseDown(VSTGUI::CPoint&, VSTGUI::CButtonState const&) + 537
13  eDRUMin                       	       0x1065ea6af VSTGUI::CFrame::onMouseDown(VSTGUI::CPoint&, VSTGUI::CButtonState const&) + 443
14  eDRUMin                       	       0x1065ee83e VSTGUI::CFrame::platformOnMouseDown(VSTGUI::CPoint&, VSTGUI::CButtonState const&) + 90
15  eDRUMin                       	       0x1066348d5 VSTGUI_NSView_onMouseDown(objc_object*, objc_selector*, NSEvent*) + 323
16  eDRUMin                       	       0x106634b5f VSTGUI_NSView_mouseDown(objc_object*, objc_selector*, NSEvent*) + 68
17  AppKit                        	    0x7ff8105ab161 -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 4859
18  AppKit                        	    0x7ff81051f30e -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 2582
19  AppKit                        	    0x7ff81051e6de -[NSWindow(NSEventRouting) sendEvent:] + 352
20  AppKit                        	    0x7ff81051cab4 -[NSApplication(NSEvent) sendEvent:] + 352
21  AppKit                        	    0x7ff8107d58db -[NSApplication _handleEvent:] + 65
22  AppKit                        	    0x7ff81039e2ce -[NSApplication run] + 623
23  AppKit                        	    0x7ff810372227 NSApplicationMain + 817
24  eDRUMin                       	       0x10657bdd4 start + 52
Thread 1:
0   libsystem_kernel.dylib        	    0x7ff80d88597a mach_msg_trap + 10
1   libsystem_kernel.dylib        	    0x7ff80d885ce8 mach_msg + 56
2   CoreMIDI                      	    0x7ff8245b7550 XServerMachPort::ReceiveMessage(int&, void*, int&) + 94
3   CoreMIDI                      	    0x7ff8245e7981 MIDIProcess::MIDIInPortThread::Run() + 105
4   CoreMIDI                      	    0x7ff8245ce482 XThread::RunHelper(void*) + 10
5   CoreMIDI                      	    0x7ff8245cf6a7 CAPThread::Entry(CAPThread*) + 77
6   libsystem_pthread.dylib       	    0x7ff80d8c24e1 _pthread_start + 125
7   libsystem_pthread.dylib       	    0x7ff80d8bdf6b thread_start + 15
Thread 2:
2   CoreFoundation                	    0x7ff80d988cdd __CFRunLoopServiceMachPort + 319
3   CoreFoundation                	    0x7ff80d987368 __CFRunLoopRun + 1276
4   CoreFoundation                	    0x7ff80d9867ac CFRunLoopRunSpecific + 562
5   CoreFoundation                	    0x7ff80da0e82b CFRunLoopRun + 40
6   eDRUMin                       	       0x1065cd8a8 rawhid_recv(int, void*, int, int) + 278
7   eDRUMin                       	       0x1065d2ec9 getDeviceHIDData() + 131
8   eDRUMin                       	       0x1065d3244 expressTimerAsThread() + 80
9   Foundation                    	    0x7ff80e7d39f4 __NSThread__start__ + 1009
10  libsystem_pthread.dylib       	    0x7ff80d8c24e1 _pthread_start + 125
11  libsystem_pthread.dylib       	    0x7ff80d8bdf6b thread_start + 15
Thread 3:: com.apple.NSEventThread
5   AppKit                        	    0x7ff81051af5e _NSEventThread + 132
Thread 4:: AMCP Logging Spool
0   libsystem_kernel.dylib        	    0x7ff80d8859b6 semaphore_wait_trap + 10
1   caulk                         	    0x7ff8163982e0 caulk::mach::semaphore::wait_or_error() + 16
2   caulk                         	    0x7ff816380102 caulk::concurrent::details::worker_thread::run() + 36
3   caulk                         	    0x7ff81637fdc6 void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*) + 41
4   libsystem_pthread.dylib       	    0x7ff80d8c24e1 _pthread_start + 125
5   libsystem_pthread.dylib       	    0x7ff80d8bdf6b thread_start + 15
Thread 5:
0   libsystem_pthread.dylib       	    0x7ff80d8bdf48 start_wqthread + 0
Thread 6:
Thread 7:
Thread 8:
Thread 0 crashed with X86 Thread State (64-bit):
  rax: 0x00000001069122f8  rbx: 0x00007fb09ea3dcb0  rcx: 0x00000001069125b8  rdx: 0x0000000000000008
  rdi: 0x00007fb0a03abc00  rsi: 0x00000001069128e0  rbp: 0x00007ff7b9985e20  rsp: 0x00007ff7b9985df8
   r8: 0x00007ff7b9985df4   r9: 0x0000000000000000  r10: 0x00007fb09ea00000  r11: 0x00007fb09eaae870
  r12: 0x0000600005adb158  r13: 0x00007fb09ea3dcb0  r14: 0x00000001069128e0  r15: 0x00007fb09e8a9fe0
  rip: 0x0000000000000000  rfl: 0x0000000000010206  cr2: 0x0000000000000000
Logical CPU:     8
Error Code:      0x00000014 (no mapping for user instruction read)
Trap Number:     14
Binary Images:
               0x0 - 0xffffffffffffffff ??? (*) <00000000-0000-0000-0000-000000000000> ???
       0x106579000 -        0x106890fff com.audiofront.eDRUMin (2.0.1) <36e4a909-3590-310c-bcca-3a364de253ca> /Applications/eDRUMin.app/Contents/MacOS/eDRUMin
    0x7ff81036f000 -     0x7ff8111fcfff com.apple.AppKit (6.9) <92a78ebd-bba5-3f18-a5e1-768c955539d7> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
    0x7ff80d884000 -     0x7ff80d8bbfff libsystem_kernel.dylib (*) <26a59789-b846-3ed4-96dc-8dbef3c0c8e7> /usr/lib/system/libsystem_kernel.dylib
    0x7ff8245a5000 -     0x7ff824611fff com.apple.audio.midi.CoreMIDI (2.0) <b156120c-8dd7-3ba0-b1ba-276abf97a506> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
    0x7ff80d8bc000 -     0x7ff80d8c7fff libsystem_pthread.dylib (*) <2f6c275d-7e14-3d31-a924-e1bb41d2415f> /usr/lib/system/libsystem_pthread.dylib
    0x7ff80d909000 -     0x7ff80de0afff com.apple.CoreFoundation (6.9) <743f0cb7-e962-3e42-8653-7bd141129561> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
    0x7ff80e77b000 -     0x7ff80eb36fff com.apple.Foundation (6.9) <3370467f-ef48-301d-97d1-cdc236b7053a> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
    0x7ff81637e000 -     0x7ff81639ffff com.apple.audio.caulk (1.0) <0b849791-3a62-33d1-8cf1-9c612a9d8e18> /System/Library/PrivateFrameworks/caulk.framework/Versions/A/caulk
External Modification Summary:
  Calls made by other processes targeting this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by this process:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
  Calls made by all processes on this machine:
    task_for_pid: 0
    thread_create: 0
    thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=920.5M resident=0K(0%) swapped_out_or_unallocated=920.5M(100%)
Writable regions: Total=739.6M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=739.6M(100%)
                                VIRTUAL   REGION
REGION TYPE                        SIZE    COUNT (non-coalesced)
Accelerate framework               768K        6
Activity Tracing                   256K        1
CG backing stores                 2688K        4
CG image                           176K       13
ColorSync                          236K       27
CoreAnimation                      568K       32
CoreGraphics                        16K        3
CoreUI image data                 1452K       15
Foundation                          44K        2
Kernel Alloc Once                    8K        1
MALLOC                           338.0M       97
MALLOC guard page                   32K        8
MALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)
STACK GUARD                       56.0M        9
Stack                             12.1M        9
VM_ALLOCATE                         84K       15
__DATA                            20.8M      344
__DATA_CONST                      15.6M      203
__DATA_DIRTY                       733K      115
__FONT_DATA                          4K        1
__LINKEDIT                       652.2M       11
__OBJC_RO                         82.6M        1
__OBJC_RW                         3200K        2
__TEXT                           268.4M      366
__UNICODE                          592K        1
dyld private memory               1024K        1
mapped file                      183.4M       32
shared memory                      784K       18
TOTAL                              2.0G     1338
TOTAL, minus reserved VM space     1.6G     1338
Full Report
{"app_name":"eDRUMin","timestamp":"2022-05-19 19:06:21.00 -0700","app_version":"2.0.1","slice_uuid":"36e4a909-3590-310c-bcca-3a364de253ca","build_version":"16","platform":1,"bundleID":"com.audiofront.eDRUMin","share_with_app_devs":1,"is_first_party":0,"bug_type":"309","os_version":"macOS 12.3.1 (21E258)","incident_id":"B12CB590-DEB6-4DEA-964A-F652923B5B6F","name":"eDRUMin"}
  "uptime" : 17000,
  "procLaunch" : "2022-05-19 18:53:24.6755 -0700",
  "procRole" : "Foreground",
  "version" : 2,
  "userID" : 501,
  "deployVersion" : 210,
  "modelCode" : "MacBookPro16,1",
  "procStartAbsTime" : 16672482366863,
  "coalitionID" : 4728,
  "osVersion" : {
    "train" : "macOS 12.3.1",
    "build" : "21E258",
    "releaseType" : "User"
  "captureTime" : "2022-05-19 19:06:15.7152 -0700",
  "incident" : "B12CB590-DEB6-4DEA-964A-F652923B5B6F",
  "bug_type" : "309",
  "pid" : 5488,
  "procExitAbsTime" : 17443524462560,
  "cpuType" : "X86-64",
  "procName" : "eDRUMin",
  "procPath" : "\/Applications\/eDRUMin.app\/Contents\/MacOS\/eDRUMin",
  "bundleInfo" : {"CFBundleShortVersionString":"2.0.1","CFBundleVersion":"16","CFBundleIdentifier":"com.audiofront.eDRUMin"},
  "storeInfo" : {"deviceIdentifierForVendor":"998833D1-1BEB-5371-A6FB-D5B582A51A7B","thirdParty":true},
  "parentProc" : "launchd",
  "parentPid" : 1,
  "coalitionName" : "com.audiofront.eDRUMin",
  "crashReporterKey" : "711093E2-26D4-FCA5-0CE3-BF0C643ED235",
  "wakeTime" : 973,
  "bridgeVersion" : {"build":"19P4243","train":"6.4"},
  "sleepWakeUUID" : "8CEC27A9-5079-4416-B633-4881E389BA28",
  "sip" : "enabled",
  "vmRegionInfo" : "0 is not in any region.  Bytes before following region: 4401369088\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      __TEXT                      106579000-106891000    [ 3168K] r-x\/r-x SM=COW  ...MacOS\/eDRUMin",
  "isCorpse" : 1,
  "exception" : {"codes":"0x0000000000000001, 0x0000000000000000","rawCodes":[1,0],"type":"EXC_BAD_ACCESS","signal":"SIGSEGV","subtype":"KERN_INVALID_ADDRESS at 0x0000000000000000"},
  "termination" : {"flags":0,"code":11,"namespace":"SIGNAL","indicator":"Segmentation fault: 11","byProc":"exc handler","byPid":5488},
  "vmregioninfo" : "0 is not in any region.  Bytes before following region: 4401369088\n      REGION TYPE                    START - END         [ VSIZE] PRT\/MAX SHRMOD  REGION DETAIL\n      UNUSED SPACE AT START\n--->  \n      __TEXT                      106579000-106891000    [ 3168K] r-x\/r-x SM=COW  ...MacOS\/eDRUMin",
  "extMods" : {"caller":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"system":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"targeted":{"thread_create":0,"thread_set_state":0,"task_for_pid":0},"warnings":0},
  "faultingThread" : 0,
  "threads" : [{"triggered":true,"id":224096,"threadState":{"r13":{"value":140396552510640},"rax":{"value":4405142264,"symbolLocation":40,"symbol":"construction vtable for VSTGUI::CView-in-AFOpenTileSelector"},"rflags":{"value":66054},"cpu":{"value":8},"r14":{"value":4405143776,"symbolLocation":0,"symbol":"VTT for AFTileSelector"},"rsi":{"value":4405143776,"symbolLocation":0,"symbol":"VTT for AFTileSelector"},"r8":{"value":140701947420148},"cr2":{"value":0},"rdx":{"value":8},"r10":{"value":140396552257536},"r9":{"value":0},"r15":{"value":140396550856672},"rbx":{"value":140396552510640},"trap":{"value":14,"description":"(no mapping for user instruction read)"},"err":{"value":20},"r11":{"value":140396552972400},"rip":{"value":0},"rbp":{"value":140701947420192},"rsp":{"value":140701947420152},"r12":{"value":105553211535704},"rcx":{"value":4405142968,"symbolLocation":40,"symbol":"vtable for AFTileSelector"},"flavor":"x86_THREAD_STATE","rdi":{"value":140396579175424}},"queue":"com.apple.main-thread","frames":[{"imageOffset":0,"imageIndex":0},{"imageOffset":1056413,"symbol":"AFTileSelector::~AFTileSelector()","symbolLocation":83,"imageIndex":1},{"imageOffset":1056101,"symbol":"AFTileSelector::~AFTileSelector()","symbolLocation":21,"imageIndex":1},{"imageOffset":475398,"symbol":"VSTGUI::CViewContainer::removeAll(bool)","symbolLocation":242,"imageIndex":1},{"imageOffset":458801,"symbol":"VSTGUI::CViewContainer::beforeDelete()","symbolLocation":99,"imageIndex":1},{"imageOffset":400891,"symbol":"VSTGUI::ReferenceCounted<int>::forget()","symbolLocation":27,"imageIndex":1},{"imageOffset":545018,"symbol":"std::__1::list<VSTGUI::SharedPointer<VSTGUI::CView>, std::__1::allocator<VSTGUI::SharedPointer<VSTGUI::CView> > >::erase(std::__1::__list_const_iterator<VSTGUI::SharedPointer<VSTGUI::CView>, void*>)","symbolLocation":46,"imageIndex":1},{"imageOffset":475134,"symbol":"VSTGUI::CViewContainer::removeView(VSTGUI::CView*, bool)","symbolLocation":314,"imageIndex":1},{"imageOffset":1610557,"symbol":"MED_Layout::showLoadFromMap(bool)","symbolLocation":573,"imageIndex":1},{"imageOffset":16179,"symbol":"AFControl::valueChanged()","symbolLocation":75,"imageIndex":1},{"imageOffset":60997,"symbol":"AFButton::onMouseDown(VSTGUI::CPoint&, VSTGUI::CButtonState const&)","symbolLocation":759,"imageIndex":1},{"imageOffset":423261,"symbol":"VSTGUI::CViewContainer::onMouseDown(VSTGUI::CPoint&, VSTGUI::CButtonState const&)","symbolLocation":537,"imageIndex":1},{"imageOffset":423261,"symbol":"VSTGUI::CViewContainer::onMouseDown(VSTGUI::CPoint&, VSTGUI::CButtonState const&)","symbolLocation":537,"imageIndex":1},{"imageOffset":464559,"symbol":"VSTGUI::CFrame::onMouseDown(VSTGUI::CPoint&, VSTGUI::CButtonState const&)","symbolLocation":443,"imageIndex":1},{"imageOffset":481342,"symbol":"VSTGUI::CFrame::platformOnMouseDown(VSTGUI::CPoint&, VSTGUI::CButtonState const&)","symbolLocation":90,"imageIndex":1},{"imageOffset":768213,"symbol":"VSTGUI_NSView_onMouseDown(objc_object*, objc_selector*, NSEvent*)","symbolLocation":323,"imageIndex":1},{"imageOffset":768863,"symbol":"VSTGUI_NSView_mouseDown(objc_object*, objc_selector*, NSEvent*)","symbolLocation":68,"imageIndex":1},{"imageOffset":2343265,"symbol":"-[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:]","symbolLocation":4859,"imageIndex":2},{"imageOffset":1770254,"symbol":"-[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:]","symbolLocation":2582,"imageIndex":2},{"imageOffset":1767134,"symbol":"-[NSWindow(NSEventRouting) sendEvent:]","symbolLocation":352,"imageIndex":2},{"imageOffset":1759924,"symbol":"-[NSApplication(NSEvent) sendEvent:]","symbolLocation":352,"imageIndex":2},{"imageOffset":4614363,"symbol":"-[NSApplication _handleEvent:]","symbolLocation":65,"imageIndex":2},{"imageOffset":193230,"symbol":"-[NSApplication run]","symbolLocation":623,"imageIndex":2},{"imageOffset":12839,"symbol":"NSApplicationMain","symbolLocation":817,"imageIndex":2},{"imageOffset":11732,"symbol":"start","symbolLocation":52,"imageIndex":1}]},{"id":224162,"frames":[{"imageOffset":6522,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7400,"symbol":"mach_msg","symbolLocation":56,"imageIndex":3},{"imageOffset":75088,"symbol":"XServerMachPort::ReceiveMessage(int&, void*, int&)","symbolLocation":94,"imageIndex":4},{"imageOffset":272769,"symbol":"MIDIProcess::MIDIInPortThread::Run()","symbolLocation":105,"imageIndex":4},{"imageOffset":169090,"symbol":"XThread::RunHelper(void*)","symbolLocation":10,"imageIndex":4},{"imageOffset":173735,"symbol":"CAPThread::Entry(CAPThread*)","symbolLocation":77,"imageIndex":4},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":224180,"frames":[{"imageOffset":6522,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7400,"symbol":"mach_msg","symbolLocation":56,"imageIndex":3},{"imageOffset":523485,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":6},{"imageOffset":516968,"symbol":"__CFRunLoopRun","symbolLocation":1276,"imageIndex":6},{"imageOffset":513964,"symbol":"CFRunLoopRunSpecific","symbolLocation":562,"imageIndex":6},{"imageOffset":1071147,"symbol":"CFRunLoopRun","symbolLocation":40,"imageIndex":6},{"imageOffset":346280,"symbol":"rawhid_recv(int, void*, int, int)","symbolLocation":278,"imageIndex":1},{"imageOffset":368329,"symbol":"getDeviceHIDData()","symbolLocation":131,"imageIndex":1},{"imageOffset":369220,"symbol":"expressTimerAsThread()","symbolLocation":80,"imageIndex":1},{"imageOffset":362996,"symbol":"__NSThread__start__","symbolLocation":1009,"imageIndex":7},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":224186,"name":"com.apple.NSEventThread","frames":[{"imageOffset":6522,"symbol":"mach_msg_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":7400,"symbol":"mach_msg","symbolLocation":56,"imageIndex":3},{"imageOffset":523485,"symbol":"__CFRunLoopServiceMachPort","symbolLocation":319,"imageIndex":6},{"imageOffset":516968,"symbol":"__CFRunLoopRun","symbolLocation":1276,"imageIndex":6},{"imageOffset":513964,"symbol":"CFRunLoopRunSpecific","symbolLocation":562,"imageIndex":6},{"imageOffset":1752926,"symbol":"_NSEventThread","symbolLocation":132,"imageIndex":2},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":224191,"name":"AMCP Logging Spool","frames":[{"imageOffset":6582,"symbol":"semaphore_wait_trap","symbolLocation":10,"imageIndex":3},{"imageOffset":107232,"symbol":"caulk::mach::semaphore::wait_or_error()","symbolLocation":16,"imageIndex":8},{"imageOffset":8450,"symbol":"caulk::concurrent::details::worker_thread::run()","symbolLocation":36,"imageIndex":8},{"imageOffset":7622,"symbol":"void* caulk::thread_proxy<std::__1::tuple<caulk::thread::attributes, void (caulk::concurrent::details::worker_thread::*)(), std::__1::tuple<caulk::concurrent::details::worker_thread*> > >(void*)","symbolLocation":41,"imageIndex":8},{"imageOffset":25825,"symbol":"_pthread_start","symbolLocation":125,"imageIndex":5},{"imageOffset":8043,"symbol":"thread_start","symbolLocation":15,"imageIndex":5}]},{"id":252332,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":260379,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":264147,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]},{"id":265434,"frames":[{"imageOffset":8008,"symbol":"start_wqthread","symbolLocation":0,"imageIndex":5}]}],
  "usedImages" : [
    "size" : 0,
    "source" : "A",
    "base" : 0,
    "uuid" : "00000000-0000-0000-0000-000000000000"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 4401369088,
    "CFBundleShortVersionString" : "2.0.1",
    "CFBundleIdentifier" : "com.audiofront.eDRUMin",
    "size" : 3244032,
    "uuid" : "36e4a909-3590-310c-bcca-3a364de253ca",
    "path" : "\/Applications\/eDRUMin.app\/Contents\/MacOS\/eDRUMin",
    "name" : "eDRUMin",
    "CFBundleVersion" : "16"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703400652800,
    "CFBundleShortVersionString" : "6.9",
    "CFBundleIdentifier" : "com.apple.AppKit",
    "size" : 15261696,
    "uuid" : "92a78ebd-bba5-3f18-a5e1-768c955539d7",
    "path" : "\/System\/Library\/Frameworks\/AppKit.framework\/Versions\/C\/AppKit",
    "name" : "AppKit",
    "CFBundleVersion" : "2113.40.127"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703355650048,
    "size" : 229376,
    "uuid" : "26a59789-b846-3ed4-96dc-8dbef3c0c8e7",
    "path" : "\/usr\/lib\/system\/libsystem_kernel.dylib",
    "name" : "libsystem_kernel.dylib"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703738515456,
    "CFBundleShortVersionString" : "2.0",
    "CFBundleIdentifier" : "com.apple.audio.midi.CoreMIDI",
    "size" : 446464,
    "uuid" : "b156120c-8dd7-3ba0-b1ba-276abf97a506",
    "path" : "\/System\/Library\/Frameworks\/CoreMIDI.framework\/Versions\/A\/CoreMIDI",
    "name" : "CoreMIDI",
    "CFBundleVersion" : "88"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703355879424,
    "size" : 49152,
    "uuid" : "2f6c275d-7e14-3d31-a924-e1bb41d2415f",
    "path" : "\/usr\/lib\/system\/libsystem_pthread.dylib",
    "name" : "libsystem_pthread.dylib"
    "source" : "P",
    "arch" : "x86_64h",
    "base" : 140703356194816,
    "CFBundleIdentifier" : "com.apple.CoreFoundation",
    "size" : 5251072,
    "uuid" : "743f0cb7-e962-3e42-8653-7bd141129561",
    "path" : "\/System\/Library\/Frameworks\/CoreFoundation.framework\/Versions\/A\/CoreFoundation",
    "name" : "CoreFoundation",
    "CFBundleVersion" : "1858.112"
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703371341824,
    "CFBundleIdentifier" : "com.apple.Foundation",
    "size" : 3915776,
    "uuid" : "3370467f-ef48-301d-97d1-cdc236b7053a",
    "path" : "\/System\/Library\/Frameworks\/Foundation.framework\/Versions\/C\/Foundation",
    "name" : "Foundation",
    "source" : "P",
    "arch" : "x86_64",
    "base" : 140703501377536,
    "CFBundleShortVersionString" : "1.0",
    "CFBundleIdentifier" : "com.apple.audio.caulk",
    "size" : 139264,
    "uuid" : "0b849791-3a62-33d1-8cf1-9c612a9d8e18",
    "path" : "\/System\/Library\/PrivateFrameworks\/caulk.framework\/Versions\/A\/caulk",
    "name" : "caulk"
  "sharedCache" : {
  "base" : 140703352606720,
  "size" : 15224815616,
  "uuid" : "6cc5ecdc-5119-37f0-9a85-4f48a50f5f78"
  "vmSummary" : "ReadOnly portion of Libraries: Total=920.5M resident=0K(0%) swapped_out_or_unallocated=920.5M(100%)\nWritable regions: Total=739.6M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=739.6M(100%)\n\n                                VIRTUAL   REGION \nREGION TYPE                        SIZE    COUNT (non-coalesced) \n===========                     =======  ======= \nAccelerate framework               768K        6 \nActivity Tracing                   256K        1 \nCG backing stores                 2688K        4 \nCG image                           176K       13 \nColorSync                          236K       27 \nCoreAnimation                      568K       32 \nCoreGraphics                        16K        3 \nCoreUI image data                 1452K       15 \nFoundation                          44K        2 \nKernel Alloc Once                    8K        1 \nMALLOC                           338.0M       97 \nMALLOC guard page                   32K        8 \nMALLOC_NANO (reserved)           384.0M        1         reserved VM address space (unallocated)\nSTACK GUARD                       56.0M        9 \nStack                             12.1M        9 \nVM_ALLOCATE                         84K       15 \n__DATA                            20.8M      344 \n__DATA_CONST                      15.6M      203 \n__DATA_DIRTY                       733K      115 \n__FONT_DATA                          4K        1 \n__LINKEDIT                       652.2M       11 \n__OBJC_RO                         82.6M        1 \n__OBJC_RW                         3200K        2 \n__TEXT                           268.4M      366 \n__UNICODE                          592K        1 \ndyld private memory               1024K        1 \nmapped file                      183.4M       32 \nshared memory                      784K       18 \n===========                     =======  ======= \nTOTAL                              2.0G     1338 \nTOTAL, minus reserved VM space     1.6G     1338 \n",
  "legacyInfo" : {
  "threadTriggered" : {
    "queue" : "com.apple.main-thread"
  "trialInfo" : {
  "rollouts" : [
      "rolloutId" : "5fc94383418129005b4e9ae0",
      "factorPackIds" : {
      "deploymentId" : 240000370
      "rolloutId" : "61301e3a61217b3110231469",
      "factorPackIds" : {
        "SIRI_FIND_MY_CONFIGURATION_FILES" : "6216ae152a40e71046e16225"
      "deploymentId" : 240000016
  "experiments" : [
Model: MacBookPro16,1, BootROM 1731.100.130.0.0 (iBridge: 19.16.14243.0.0,0), 8 processors, 8-Core Intel Core i9, 2.3 GHz, 16 GB, SMC
Graphics: Intel UHD Graphics 630, Intel UHD Graphics 630, Built-In
Graphics: AMD Radeon Pro 5500M, AMD Radeon Pro 5500M, PCIe, 4 GB
Display: Color LCD, 3072 x 1920 Retina, Main, MirrorOff, Online
Memory Module: BANK 0/ChannelA-DIMM0, 8 GB, DDR4, 2667 MHz, Micron, 8ATF1G64HZ-2G6E1
Memory Module: BANK 2/ChannelB-DIMM0, 8 GB, DDR4, 2667 MHz, Micron, 8ATF1G64HZ-2G6E1
AirPort: spairport_wireless_card_type_wifi (0x14E4, 0x7BF), wl0: Jul 12 2021 18:02:56 version 9.30.464.0.32.5.76 FWID 01-c081cfed
Bluetooth: Version (null), 0 services, 0 devices, 0 incoming serial ports
Network Service: Wi-Fi, AirPort, en0
USB Device: USB31Bus
USB Device: eDrumIn BLACK
USB Device: T2Bus
USB Device: composite_device
USB Device: Touch Bar Backlight
USB Device: Touch Bar Display
USB Device: Apple Internal Keyboard / Trackpad
USB Device: Headset
USB Device: Ambient Light Sensor
USB Device: FaceTime HD Camera (Built-in)
USB Device: Apple T2 Controller
Thunderbolt Bus: MacBook Pro, Apple Inc., 63.5
Luckymethod
Ok I figured out something I was doing wrong, but there's still a problem. Where it lets you select the drum map from a drop down, it's only showing the factory presets but not my user created map. Not sure it's a bug or by design, but the drop down is really not obvious or easy to spot and not being able to use my own template is a major issue.
Hope that helps.
