eDRUMin version 2 BETA
Re: eDRUMin version 2 BETA
Wed Apr 27, 2022 10:10 am
I'm not seeing an issue. Can you post your hihat settings?
Thanks Rob, I'll be at my kit later today and will upload them here.
MisterE wrote:
Wed Apr 27, 2022 1:15 pm
I booted V1.6 and flipped on the eDRUMin10 using the settings that had been stored from V2.
I'm still getting two closed hi hat sounds as I depress the pedal.
Thoughts?
EDIT: I deleted my preset, uploaded the preset for VH12 and the problem is solved. No more double chicks. Hi hat plays as it should. I will now tweak to my original playability. All good!
Bug to report. HH cymbals are not sending correct poly aftertouch midi notes. HH cymbals bow and edge midi notes are 46 and 26 (Roland TD-17 map), but the midi monitor shows the poly aftertouch midi notes is 18 and 19.
I changed the drum kit map to SD3, which for me the bow and edge midi notes are 8 and 7, and no change to the poly aftertouch midi notes. Remains 18 and 19.
I have a VH13 and VH10 (xhat) plugged into a ED43, and both of the inputs are set to Hihat Cymbal. They both have the same issues.
Dadwrshpdrum wrote:
Wed Apr 27, 2022 7:07 pm
Confirmed. I'm not entirely sure what to do here. If the hihat is setup to 'CC mode', then things are straight forward. But what If the hihat is setup as 'levels mode', what values should I be sending? I think if it's setup as levels mode, I'm still going to send the notes defined in the Hihat Kit Piece.
Update: Fixed for the next build.
MisterE wrote:
Wed Apr 27, 2022 3:00 pm
Thoughts?
PLOT THICKENS: After much investigation and manipulations which I cant recount, the double chicks returned on occasion. Each time, I was able to solve it by uploading the Roland VH12 preset.
I know you posted a pic from version 1.6, but are you back to using version 2? If you are, please post a screenshot from version 2. Preferably one with the calibration range control visible.
Thu Apr 28, 2022 1:31 am
I'm out of town so I can't provide settings but I will when I'm back home. In any case, yes, I'm using version 2 very successfully now. Everything is dialed in so incredibly well and I saved all my pad/cymbal trigger settings, my custom Mimic map and the entire eDRUMin 10 module.
I posted build 40
  • Fixed hihats sending wrong aftertouch messages for choking.
  • Fixed 3-Zone metal cymbal not sending aftertouch to choke bell articulation.
  • Smoother and more reliable UI scaling.
  • Dozens (hours and hours) of small UI refinements that probably only I will notice.
Wed Apr 27, 2022 8:42 pm
Thanks fixed for CC mode (that is all I use)
Not sure if this is a bug. What I noticed today that loading a preset with only trigger settings and velocity curve selected the drum kit piece assignment loads as well. I guess I was expecting when loading a preset with midi assignment deselected the existing drum kit piece would remain unchanged, and not be updated to whatever the preset had as a drum kit piece.
