36KrazyFists
Post by 36KrazyFists »
Hi All,
First timer here. Just got my eDrumin 8. Was hoping you guys could clear up a quick bit of confusion for me:
I have a Lemon 13" triple zone (dual output) ride cymbal (LE-13CR3) that I can't get the Bell feature working on in eDrumin, so I took to the forums and did some searching and found another thread that Rob himself replied to saying that Lemon bell sense doesn't work and will probably never work with the eDrumin (this post here if you're interested). However, in the main post of this thread, the Lemon 3 zone dual output rides are listed as working with bell sense using the Roland 3 zone dual output selection (which I've tried).
Obviously I understand this is an unofficial support thread, but are there different Lemon 3 zone rides that work in different ways and some do have a working bell sense feature? I'm only asking because I was ready to return my Lemon and spring for a Roland, or should I keep working on it?
Thanks for the lovely community you guys seem to have here by the way!
Bell sense is a feature where a hits to the bell can be detected without using both inputs of a 3 zone cymbal. Bell sense works for select Roland cymbals, but not Lemon cymbals.
However, using the both cables, you should no problem getting all three zones (bow, edge, bell) from that cymbal using the 'Roland 3-Zone Ride' padtype.
36KrazyFists
Thu Aug 22, 2024 1:37 am
Yep, I get that now. I guess I should have read more of the manual and/or watched some of your videos before posting :-)
I think the problem is my Lemon ride doesn't seem to be outputting anything from the second output... I think it might be broken. I've already ordered a used Roland 3 zone and am returning the Lemon one.
Thanks again!
edouard300
Post by edouard300 »
Hey everyone!
I am really eager to get an eDRUMin for my recently purchased FED 1200W from Fesley.
It was the best price/quality relation I could find, and I'm very happy with it. The only lacking aspect of it is the module, it feels a bit limited, while it triggers nicely, it doesn't have much customization and fine tuning, which is quite badly needed for the hihat specifically.
I only really use it for triggering with MIDI on my PC, reason why I'm interested in eDRUMin.
So my question is, does anybody know if it's compatible with Fesley drumkits? Specifically the FED 1200W.
Thanks in advance!
electronics drums pads are simple beasts and I think you'll be hard pressed to find one's that aren't compatible with eDRUMin modules. The only question mark would be the hihat implementation. There is a separate cable for the hihat cymbal and hihat pedal? I looked for the user manual but didn't find one.
stringerbell
Post by stringerbell »
A question to the people using the goedrum GHC hi hat controller: can you specify which model/version you are using? My search for goedrum GHC on Ebay results in a couple of moodels:
  • GHC
    GHC-AC
    GHC-AN
    GHC-Y
    GHC 2
Now my best guess is these are newer, so the people that have mentioned using it are likely using the first one in the list, but if this is not the case, or people have experience with the other models, it would be great to know!
A side node: Thanks all for sharing your experience here. My edrumin 10 is on the way here, and I'm very (veeeeerrryy) excited to start building and customizing my kit (without single-brand limitations!)
STP
Post by STP »
A question to all who can help me.
I tried to hook up my 14 inch Unlock hihat cymbals with the eDrumin 10, it says compatibility problem!
Robert, is there a solution?
Greetings Steve Boston
You can disable the compatibility check, but it's likely indicating a problem with the cymbal or cable.
STP
Post by STP »
Thanks for your fast reply, I will check the cables.
STP
Post by STP »
Cables are working, chose the VH-13 for the hihat! It works!
Still working to adjust my snaredrum(DrumTec Pro 14inch) first and then I will adjust the rest of the pads.
The last steps will be adjusting everything in Superior Drummer 3
I wonder what is the best to do:
Using two eDrumin 10 to separate usb inputs to pc or connect one eDrumin 10 with the usb host to the other.(usb B to usb A right?, not A to A!)
What will be better/easier and what is the difference considering the crosstalk.
Thanks for your time and help.
Greetings Steve
