eDRUMin version 2 BETA
Re: eDRUMin version 2 BETA
I've posted build 35. I moved the advanced mode button to the preference menu (eDRUMin logo). Firmware is still build 34. I've also posted this as a BETA release on the main download page.
mrmbira
Post by mrmbira »
Hi Rob, I am curious why the dual zone cymbal has a choice for 'Roland 'or 'other' on the positional setting but the center triggered mesh head drum doesn't have this option on the positional setting?
Because of this, the dual zone cymbal setting is the only setting that will work for my DIY drum pad. I realize there is probably a good reason this is left off the center mesh head pad type but it would be cool to have it. thanks, Mbira
MJWoeb1962
Post by MJWoeb1962 »
Figured it out!
The mapping for the mimic pro is missing the pedal notes, using CC mode to trigger the hihat, the mimic supports 2 separate notes for tight edge and tight bow, can you implement those in the edrumin? The notes are F#3 for bow tight and F3 for edge tight
Can't be implemented using CC mode. Use hihat levels mode instead. CC is still sent when using levels mode.
I see, didn’t know that, so I just put all the other intermediate levels to note zero?
No, not zero. Set them to the regular bow and edge notes. I wouldn't be surprised if the mimic drumap is already setup this way.
The mimic has G#3 for Bow and G3 for Edge, which is set to 61 on the edrumin by the way, so I'll set all to these then.
The Mimic Pro Drum Map (Hihat Levels Mode) is based on this information:
Assuming that the above information is correct, then it should already be working properly in version 2.
G3 is 67 not 61
