Thanks, for the scan and hold I used the default value from the calibrate.
I ajusted them now and tweaked other setting like the value of HSS. It's becoming better and better.
Now the flam are really better but sometimes there's still a spike on the second hit.
There is 2 hits registered but it seems the second when I hit directly on the cone the HSS reduce the signal less than usually.
I would say it's 100% better and I can play it now except for some hit that spike a little bit.
Here's a screenshot of my new setting with a spike from a flam like I talk about.
Velocity curve
Re: Velocity curve
- flam.png (82.75 KiB) Viewed 382 times
