Hihat Stealth conversion module / 2box
Dewaaachner
Re: Hihat Stealth conversion module / 2box
Post by Dewaaachner »
Ok, thank you Rob.
I guess, it will be easier to check and go for some of the other DIY hihat solutions then ...
Cheers, Frank
Drumit5 & eDRUMin, stealth cymbal Triggers, Millenium low noise Cymbals
flaphead
Post by flaphead »
Have a look at the hall-sensor thread in the DIY section here. I just followed this guide and built my own hall sensor this weekend. Took me about 2 hours to finish and works great!
Dewaaachner
Yes, saw it already. Thanks.
Beeing used to playing hall effect pedals (ddrum & 2box) I would prefer this. Also, no mechanical wear to be expected is a big advantage to me.
In the manual there is a wiring diagram and reference to a compatible sensor. It doesn't offer the greatest resolution, but it's easy to build uses current from the eDRUMin, so there's no need for external power.
Dewaaachner
Thank you Rob & Flaphead, just ordered a honeywell ss49e and going to try a build, powered by the edrumin.
Cheers, Frank
I use one of this, made by drone triggers in the UK, it's an optical controller with reflection plate and works perfectly with my diy cymbal.
https://www.ebay.co.uk/itm/Optical-Hi-H ... Swjqlf9eYn
Dewaaachner
Cool. Looks good...
Thanks for sharing... haven't noticed that type of pedal sensor before.
lalo wrote:I use one of this, made by drone triggers in the UK, it's an optical controller with reflection plate and works perfectly with my diy cymbal.
Dewaaachner
So, did it today. Indeed, easy to build.
I copied the ddrum4-design, where the sensor is fixed at the pad and the Magnet is mounted like a clutch.
Woodbase with sensor, to be mounted under the cymbal
BaseplateTopView
BaseplateTopView
Woodbase side view
BaseplateSideView
BaseplateSideView
Hihat-Cymbal with cutout for sensor (glued in)
Cymbal
Cymbal
Dewaaachner
Magnet glued to the clutch
Works great :)
nice, post a short video demoing it, otherwise "sounds great" doesn't mean anything to me 8-)
