- F12BE711-7F47-406E-870A-E60D8B65A9BF.jpeg (254.07 KiB) Viewed 1417 times
Expression pedal tracking
Re: Expression pedal tracking
No worries, I wonder if it could potentially be the plugin as well. Again appreciate the help.
I've fixed the installer. Download again and you shouy be able to properly update your firmware.
Installed and it updated the firmware just fine.
Has that resolved your issues?
Sorry for the delayed response, I hadn't had time to check yet. It did seem to help a little, but still seeing some of the lagging or issues with the position seeming to stop about 2/3 of the way through the full movement and then jumping to the end position after some time.
If you can make a short video of what's happening in the control application that would help me diagnose the issue.
Rob,
Can you let me know what file extensions will work? I tried as a .mov and .mp4 and both came back as invalid.
Send it to support at audiofront dot net.
Sent it this morning, thanks for looking further into this.
