Wiring question
Re: Wiring question
Now I’m thinking g my problem lies with the 35mm piezo and trimpot combo. Basically the threshold meter on HSS is never activated. And I have a pretty bad hot spot still despite tension and height of cone changes. I’m pretty sure I’m all good there. This is abnormal, right? I’m going to switch it for a 27mm and report back.
Re: Wiring question
Welcome to my worldAKA Wayne wrote:Now I’m thinking g my problem lies with the 35mm piezo and trimpot combo. Basically the threshold meter on HSS is never activated. And I have a pretty bad hot spot still despite tension and height of cone changes. I’m pretty sure I’m all good there. This is abnormal, right? I’m going to switch it for a 27mm and report back.
![Smile :)](./images/smilies/icon_e_smile.gif)
Make sure your tension is tight.
Do you see if the hotspot clip? If yes the HSS can't detect because it doesn't see all the signal.
Re: Wiring question
The tension is definitely tight enough. And yes it is clipping. I’ve got it switched to a 27mm. Just need to unhook the trimpots and hopefully test today.
Re: Wiring question
Sounds correct to me.
