Jazz Swirls & Sweeps, Nylon brushes?
Re: Jazz Swirls & Sweeps, Nylon brushes?
In the input section there's a 'brush' mode icon. The way it works is that that the plugin passes the raw sound from the pad (you can here is on the track that DSPT is inserted on). The idea is that you can combine the sounds from DSPT with the sound from your drum sampler.
