Wacky hi-hat using eDRUMin
Re: Wacky hi-hat using eDRUMin
You're not getting as much voltage range as you should be getting. Take the hat off and push the plunger with your finger and see if you can make it travel further.
TheJay
Post by TheJay »
Hello Rob, either way it moves about 1cm.
It's moving about 10%. That's not great. My VH-10 / 13 move about 35%. Can you try changing the pedal type to expression pedal and see if that makes a difference?
TheJay
Post by TheJay »
Good job, after experimenting I removed a piece of plastic that stopped it travelling and now there isn't any blue showing after calibration. What next, still not getting a different noise for partial and full open.
Can you please post another video of you calibrating now so I can see what the voltage range is looking like?
TheJay
Post by TheJay »
That's looking a lot better. I suspect, although I could be wrong, you could get even more range by rising your hat a tiny bit. But it's probably fine as is.
You don't need to make any other changes on the eDRUMin. Any other issues are going to be settings inside SD3.
I suspect you changed some settings in SD3 while you were trying to get it to work? I'm away from my studio at the moment, but when I'm home I'll send you some screenshots of my settings.
TheJay
Post by TheJay »
Thank you Rob,that's very kind. I've got the hi hats mounted so there's an inch between them when they are open by the way.
An inch should be more than enough.
Sly
Post by Sly »
The go edrum hihat is know to not work well with a bottom cymbal. Usually, when the top and bottom are fully closed, the controller is not at his max. Maybe your problem come from that.
A guy has even 3D printed a piece to avoid this problem, see this vid at 10'30" : https://www.youtube.com/watch?v=658bexvAPyI
