Can't find DSP Trigger in Cubase
hodini
Re: Can't find DSP Trigger in Cubase
Post by hodini »
I found it on the blacklist says it's unsupported.
What version of Cubase?
hodini
Post by hodini »
It's in with the blacklisted 32 bit plug ins.
hodini
Post by hodini »
Elements 10.5
hodini
Post by hodini »
Lemme know if you figure out what I'm doing wrong as it's giving me a headache.
I quick search shows several posts on issues with Cubase seemingly randomly blacklisting plugins.
I suspect it's blacklisting the 32 bit version because 32 bit plugins are no longer supported. That makes sense.
I would uninstall DSPT, and then reinstall and uncheck the 32bit version so it doesn't get installed.
This is a low priority for me, but if I find time later in the week, I'll investigate. I think your best bet right now for a solution is check what of people did to resolve their issues.
hodini
Post by hodini »
Fair enough Rob. I hope you know I'm on your side and rooting for this product to rock ass. Peace, and good luck with all this.
