Have you updated to the 1.3.0.7 beta? I think the big hi-hat change came in 1.3.0.5. After that version you can "step" the high hat as fast as you want and just get the chick sound if you don't let go of the pedal. Overall it plays fairly close to an actual hi-hat which is pretty amazing.
If you install it go into the pedal input and press the link button. Then all the input icons become selected. Then click the one that your hi-hat cymbal is plugged into.
I'm struggling with my hall sensor HiHat pedal (again)
- dsteinschneider
Re: I'm struggling with my hall sensor HiHat pedal (again)
Thanks, I took the beta update and it feels MUCH better to play now, I'm unsure what all these new settings do but this is an improvement to be sure.
Sorry to ressurect this thread,
does anyone know where I can buy a good pack of hall sensors? I bought x5 recently and they don't work, I'd like to make some backups and also start creating my shaker pedal
