Question on cables and splitting
Re: Question on cables and splitting
Just change the input mode to mono. It doesn't matter what pad type.you set.
right, yeah it just works, if ain't broke don't fix it :D
Coloredtoad
Post by Coloredtoad »
I had a question about cable splitting also. I read that on some devices if you use a Y cable to split a tom and kick or a tom and crash, etc into 1 input that you can't hit both of those things at the same time, is this true with the Edrumin10??
With both ED4 and ED10, you can hit both at the same time. They act as independent inputs.
Coloredtoad
Awesome!!! Thanks for the quick reply.
