Cable Splitter
arkserg
Re: Cable Splitter
Post by arkserg »
Mylo wrote:Thanks everyone for the input. This is what Musicians Friend had so I grabbed it.
https://www.musiciansfriend.com/accesso ... 4f-y-cable
I believe it will not work, you really need to separate ring from tip.
Probably the easyest way (if you don't want to solder stuff) is to get mini jack to 2 RCA cable, one mini jack to TRS adapter and two RCA to TS adapters. It will look terrible, but should work :)
Re: Cable Splitter
Should work fine.
arkserg
Re: Cable Splitter
Post by arkserg »
Actually it probably would work, I missed that it stereo to 2 mono (thougth it stereo to 2 stereo splitter), my bad. :)
Re: Cable Splitter
This splitter worked. I ended up putting my bass drum and single zone China on one jack.
Coloredtoad
Re: Cable Splitter
Post by Coloredtoad »
Re: Cable Splitter
Looks good.
Coloredtoad
Re: Cable Splitter
Awesome! Thanks Rob!
