HXM Cymbal
Re: HXM Cymbal
I suspect you have some bad cables.
scoTTTimo
Re: HXM Cymbal
Post by scoTTTimo »
Re: HXM Cymbal
Well, those certainly look they are probably not the issue. It might have to do with how you are connecting and disconnecting your pads. If you are leaving the cables plugged in while swapping cymbals, that might confuse the eDRUMin's switch detection. Build 35 a has an extra tweak to recover from that sort of situation, so if the issue happens again, you might give that a go.
Re: HXM Cymbal
I would still not rule out a bad cable.
98% of all my woes have been a bad cable, whether it is an input cable, a MIDI cable, etc.... It can be intermittent. Sometimes, angled just right, the connection is good, but turn it around in the jack and suddenly, trouble.
I doubt it is a bad input jack in the eDRUMin.
scoTTTimo
Re: HXM Cymbal
Post by scoTTTimo »
Thanks. I was swapping cymbals with the cables plugged in. Maybe it was that.
