MIDI Expression 2.9.3 BETA is available
Re: MIDI Expression 2.9.3 BETA is available
Thanks for the feedback.
vanceg
Post by vanceg »
This is great news about 14bit CC and the ability to support 3 switch pedals. I'm really looking forward to trying that out (though very few devices or software support it - interestingly good ol Ableton Live does support it, as did the old Behringer BCR2000)
Anyone have an existing easy diagram of how these 2 switch pedals are wired? I'd like to connect three momentary buttons to one input.
03-30-2024, 06-23-35.png (80.19 KiB) Viewed 2471 times
eviled
Post by eviled »
I just got my Midi Expression interface to use it with the TC Switch 3. I upgraded to the latest 2.9.3.10 firmware and tried it out. Unfortunately it seems not to work for me - if I select the 3 button footswitch, the press of the 3rd switch is registered as presses switch 1 & 2 together...
Thanks. I'll investigate.
I don't actually own the TC-3, but rather made the circuit myself. Looking more closely at the schematic for that footswitch I see that the forward voltage drop of those diode is 1.1V, but the diode's I used during testing were the typical 0.7V. I'll order some new diodes and make the needed adjustments.
eviled wrote:
Sat Apr 06, 2024 3:25 pm
Can you give build 11 (linked on the first post in this thread) and let me know if it gets your 3 button footswitch working properly?
eviled
Post by eviled »
Tue Apr 16, 2024 4:58 am
Just downloaded the new version and tried it out - unfortunately still no success. The third button of my TC Switch 3 is still recognized as a press of buttons 1 and 2. And in the firmware section the new one now shows up as 2.8.3.11 ... (and the Midi Expression Control app asked me to downgrade the firmware version)
I accidentally typed the wrong build number. I'll fix it when I get home in about an hour. The firmware will definitely need to be updated for the pedal to work properly.
Should be good now. Redownload and reinstall.
