Metal 3 zone Ride no response?
Re: Metal 3 zone Ride no response?
I've spent hours testing, and now for piece of mind I will need to test again. I understand that you're are in DIY territory, so I would take a close look at your connections.
Just quickly tested again, and no issues here. I was able to trigger BOW, EDGE, BELL, and CHOKE.
Are you posting another fix?
Thankx for your time. Gotta be crazy for you regression testing everything.
Bring retired engineer, i know the pain
Thankx again
Thankx again
I'm saying that I don't think there's anything that needs to be fixed. My tests indicate that there is no issue.
Hi Rob, sorry not getting back.
guess i was confused about you mentioning input 1 and 2 were seen as 3 zone and you were going to fix it.
But, in any case, i pulled cables and reconnected, pull usb and plugged that back in, and restarted edrumin. Looks like everything is working as expected. Must have been a long night i guess.
But, this is very cool. Glad i waited to DIY the 3 zone ride until I got the long awaited new deliveries on your modules
Now onward to the HiHat
sorry wasting your time and effort !!
- Screen Shot 2022-11-17 at 1.41.19 PM.png (256.08 KiB) Viewed 920 times
I did fix that issue, thanks for reporting it. I typically make a reply in the BETA thread that I posted a new build and then update the download links on the original post (currently 2.1.1.4). Glad everything seems to be in order.
aaah ok Rob thankx. I'll make sure i always check the updates..thankx again
