Optical hi hat
AKA Wayne
Re: Optical hi hat
Post by AKA Wayne »
More pics.
AKA Wayne
Re: Optical hi hat
Post by AKA Wayne »
Will you post some pics of your setup and your calibration range on the edrumin?
AKA Wayne
Re: Optical hi hat
Post by AKA Wayne »
I can confirm that the optical controller can be powered through the input of the edrumin. I connected the tip to vcc and ring to ao. I set the pedal to expression. It worked right away although I had to invert. Although the calibration range is half the size as it was when powered but a 5v adapter, it is now much more precise and smooth. Before it seemed too sensitive or jerky, I don't know how to describe it. I have not played it in practice but the edrumin monitor is much smoother now that it is powered by the edrumin.
Re: Optical hi hat
Awesome chris. At least we have both ways👏👍
AKA Wayne
Re: Optical hi hat
Post by AKA Wayne »
Question for Rob. Currently running my controller using the expression setting now on a ed4 r1. It is working fantastic but was wondering if I could see an improvement if I move it to my ed4 r4. I know some pedal circuitry has changed. Guess I just want to know I'm experiencing the best of the best. Thanks Rob.
Re: Optical hi hat
Should work better on ED4R4.
AKA Wayne
Re: Optical hi hat
Post by AKA Wayne »
Wed Jan 25, 2023 2:21 am
Thanks man. I'll give a comparison when I get some time. Can't imagine it being much better but I gotta try. I gotta say I am so in love with your device. I've been using edrumin since the ed4r1 and it just keeps getting better and better. And your involvement in this product/community is unreal. Thanks so much.
Re: Optical hi hat
AKA Wayne wrote:
Tue Jan 24, 2023 5:40 am
Hey Chris,
This is what i have with the wiring. HiHats are 3/4" spaced. When you reversed, only option was Yamaha Style and invert for me? ... see pic
Also, getting v4's and v5's when hihat open without using pedal. not sure what that is all about unless that is normal. May have to ask Rob.
Edrumin Snapshot_3.png (310.86 KiB) Viewed 1187 times
Re: Optical hi hat
IS this referring to 2.1.1 build 4 vs 2.1.1 build 5?
Re: Optical hi hat
No it's not. It's referring to the hardware revision of ED4 and nothing to do with software / firmware.
