eDRUMin version 2.1 BETA
Jf450
Re: eDRUMin version 2.1 BETA
Post by Jf450 »
Ronyd wrote:
Fri Sep 16, 2022 10:30 pm
Jf450 wrote:
Fri Sep 16, 2022 7:47 pm
Just a heads up. I upgraded to 2.1.0.1 and it changed my bass drum pad type from mesh center piezo to Rubber pad. I was getting weird triggering with the bass drum when hitting my ride at the same time as the bass drum, the bass drum hit would not register. I changed it back and it seems to be fixed.
Thankx I’ll keep an eye 👁 out for that.
Btw, did you select any pad preset for the kick ?
No, my kit is custom so I just picked the pad type and tweaked the settings myself.
I just upgraded.
I don't see the 3 mesh side sensor pad type?
thankx
Screen Shot 2022-09-17 at 11.56.47 AM.png (967.41 KiB) Viewed 2747 times
Luckymethod
Post by Luckymethod »
I'm having quite a few issues with this version, I made a video to show them:
https://photos.app.goo.gl/xZxJ3dGjwisbvuhz8
Luckymethod wrote:
Sat Sep 17, 2022 7:41 pm
Bummer... Wondering if it's a edrumIn10 issue.
I'm Not having issues with edrumin4. Just don't see the 3 edge trigger mesh pad on the main screen
Hopefully Rob will your issue soon
Ronyd wrote:
Sat Sep 17, 2022 3:58 pm
You updated the softwre, but you didn't update the firmware. Notice the orange exclamation mark on the bottom left hand corner.
Well, I wouldn't say 'quite a few issues', but rather one issue--albeit a very significant one. Seems like the ED10 is half crashing? Thanks for the report and video. I'll see if I can reproduce it.
If you still have version 2.1 firmware installed, it would be helpful to know it the software is still responsive before you hit any pads. Like if you switch between inputs, does the UI update properly?
UPDATE:
It's possible that the the issue was with the control application and not the firmware (the pad were still triggering after all). In build 3 a fixed a bug that could lead to lead to undefined behavior. Maybe updating to build 4 will resolve your issue.
Sat Sep 17, 2022 10:19 pm
aaah daah :oops:
thankx Rob
Ok updating firmware successful and have 3 mesh side sensor pad type.
Note:
1. Rack and Floor Toms are using splitters and no issue with previous version 2.0.2.2.
2. Rack Tom 2 and Floor Tom2 are plugged into the Ring of the splitters.
Issue:
- Hitting each drum in sequence order: snare, tom1, tom2, floor tom1 floor tom 2 no issues.
- Changing sequence : striking tom2 and/or floor tom2 not detected. I have to go back and strike Tom1 to detect strikes on Tom2, and strike Floor Tom1 to detect strikes on Floor Tom2.
Fixed for the next build. Thank-you.
Sun Sep 18, 2022 12:53 am
thankx Rob, glad to help ring out issues. So much going on impossible to test all configurations.. We are here to help, well i hope so 8-)
