Thanks for saying that! I feel less bad now. I am currently based in Brazil - and using local banking systems. The sad thing is that we can't just switch Warsaw for something else. It is truly paralysing. Does any of your Brazilian friends use an eDRUMin by any chance? It would be good if they could try to run the eDRUMin app - no hardware required, just the app. If it would be like me the app would open and close so quickly you would think it never opened. But if you remove Warsaw then it opens just fine.dsteinschneider wrote: ↑Tue Sep 13, 2022 9:45 pmHi Rob,
I've got some close Brazilian friends here in the US. I support their tech and I've been dealing with Warsaw weirdness for years. It totally makes sense that was the issue.
Doug
eDRUMin App on Windows doesn't start (problem located! :-)
Re: eDRUMin App on Windows doesn't start - anyone else having this problem?
- dsteinschneider
Re: eDRUMin App on Windows doesn't start (problem located! :-)
We ended up dedicating a an old laptop (updated with Win10 and SSD) to banking.
