Just updated to the latest firmware and the false rimshots are gone!Rob wrote: ↑Mon Jan 17, 2022 4:59 amI think I know what could be causing the issue and I have a couple ideas as to how I might implement a fix, but you're going to have to wait until the next version is in BETA to test the fix. In the meantime, you might find that the issue goes away if you try another input.
Rob, did you do a fix? If so, many thanks for doing it and fast!
Cheers!
