Did you make your DIY Controller work with a Yamaha Module? Can you confirm that although a Yamaha Module expects incremental steps from a HH Controller, they can receive continuous Hi Hat controller information and send it out as MIDI CC?perceval wrote: ↑Tue Jan 11, 2022 3:38 pmSorry, I just noticed this thread.
Here is a circuit to use when using a FSR based HH controller, as Roland does.
Myself, I just bought a FSR pad for $15 and placed it under my HH pedal with a wood platform and some foam.
You can view the circuit here on VDrums:
https://www.vdrums.com/forum/advanced/d ... post817392
Hope it helps.
Also what FSR pad did you buy?
Thank you,
Daniel
