eDRUMin in Live Touring Environment
mobleywho
Re: eDRUMin in Live Touring Environment
Post by mobleywho »
dsteinschneider wrote:
Mon Oct 11, 2021 10:38 pm
@mobleywho - I'm using a normal 5 piece kit for my studio. I've been thinking about creating a second kit for small venues and jam sessions. Your design is interesting. Please let us know how it holds up. Thanks
Will do...had my first gig with it last weekend. Big outdoor stage with huge woofers underneath and pretty loud monitors. Everything worked a treat...I didn't even have to adjust the thresholds. Obviously, I'll give it more of a run before declaring it a success, but the first outing couldn't have gone more smoothly. Rob's created an amazing tool and it integrates with my rig amazingly well.
Glad to hear first event went smoothly. I'm hoping you can keep us updated over time with how it goes. I might be the second to dive in with a small A2E kit in my case for small venues.
hb1980
Post by hb1980 »
Thu Sep 16, 2021 8:42 am
A global thresh compensation control for the entire device might be a good feature for use in live situations.
Sorry to piggyback on this thread, but this would be a fantastic feature Rob! I use the edrumin 10 live. Normally I have the threshold settings set quite low to give me the best possible dynamic range. It's not often an issue so I like to keep them that way, but for example I was playing at a wedding at the weekend and the fact my drums were on floorboards vertical to the (dancing) audience caused some interesting mis-triggers!
Needless to say, no one else noticed, but the odd floor tom/tambourine etc. going off was a bit distracting and in those situations you don't have time to make pad by pad adjustments, so a global 'offset' would be extremely useful.
I'd be really grateful if you'd consider implementing this. Thanks!
mobleywho
Post by mobleywho »
Tue Oct 26, 2021 12:49 pm
Just updating this for posterity. It's been about a dozen shows with this setup, in rooms ranging from 250-2000 capacity, indoor and outdoor, quiet stages and very loud stages (with stage-shivering subwoofers). I'm pleased to report that my eDrumIn has functioned perfectly. For whatever reason, I have had to make threshold adjustments on one of the triggers on a couple of occasions, but the software made that a quick task, easily accomplished within the scope of a sound check.
I really don't know what else I could ask for out of the unit that it isn't already delivering. If anyone else is thinking of taking this particular plunge, my experience would suggest that there's no reason not to.
Thanks for sharing - good heads up to be ready to adjust thresholds. I'm in the middle of building up a second kit to take to jam sessions.
Rabidreject
Post by Rabidreject »
Love how routed all the cables through the via xlr connections. May have to steal that...
OftheSeven
Post by OftheSeven »
Want to revisit this topic.
I'm planning to use my A2E setup live in a few months. I use 2-eDrumin units to a usb hub -> MacbookPro 16" -> usb-c MOTU M2->headphone and line out to mixer.
It works great with SD3 but I'm looking for something with multiple outputs so I can send the snare, kick and OHs to separate channels on the mixer for FOH.
I know there are a lot of audio interface options. Any recommendations for units with multiple outputs and low latency, stable with Mac? I don't need a nice AD, just decent DA and good headphone outs. Internal mixer would be a plus.
OftheSeven wrote:
Sat Feb 05, 2022 9:45 pm
I just play at home. I did some research for a similar interface. Scarlet 18i8 might be what you are looking for.
Hi guys!
Yeah, I see! Years ago, I grabbed a used M-Audio Fast Track Ultra (8x IN, 8xOUT) and it's still here working with
SD3. Multiple Outputs are great. I have the monitors speakers, the headphone amp, the buttkicker amp...
Now, I think I would go for a TASCAM device:
https://www.sweetwater.com/store/detail ... -interface
or the 8x8 version. Or that thing:
I also love these devices:
https://www.sweetwater.com/store/detail ... ital-mixer
This might also be an option, if you do some in ear monitoring etc. I guess, the XR18 could be used an ASIO audio
interface. And you have lots of monitor outs!
Greetings!
OftheSeven
mprinz wrote:
Sun Feb 06, 2022 2:59 pm
Hi guys!
Greetings!
The XR18 is an interesting option as it can double up as a small mixer for other events. I'm curious how the latency is when going usb to a computer.
I just tried a MOTU 624 and was able to get it to output 6 channels from SD3 to independent outputs on the back AND I can create a headphone mix of the 6 channels for the drummer. I can also mix in live channels (vocals, instruments) to feed into the headphone mix. Plan to try it at an upcoming rehearsal.
