3 zone Lemon cymbal with only 1 input
Re: 3 zone Lemon cymbal with only 1 input
Oh dear, time flies! :roll:
Half a year later I make it to "convert" my 3 zones Lemon cymbals to a Yamaha style 3 zones cymbal.
At least 2 of them: The 18" ride and one of the 15" ones I am using as a hihat. The four 15" crash cymbals will follow,
no later than during the Xmas holidays. :D
Ok, see what I have done:
https://drive.google.com/file/d/1NLCVyO ... sp=sharing
Greetings!
But... I noticed, triggering in the eDrumIn control software is consistent but in SD3 I get some "Xtalk" between
bell and tip trigger. I have to check the midi mapping.
mprinz wrote:
Sun Dec 19, 2021 12:49 am
Greetings!
this mod is not for me, but ...
legend
you are a prinz among drummers
Haha, thank you!
Now I have some issues with the 18" ride.
On medium to heavy hits on the bow it closes the edge switch, or I get at least a edge trigger.
The other "modified" cymbals do not show this behaviour.
I thought of a short circuit, or some unisolated wires, I rebuild everything but still that behaviour.
Hmmm, when I use the dual zone cymbal input setting, every thing is fine.
Just a thought: Is it possible, that for very high piezo output or unlimited piezos
the module detect some "leakage" through ground?
There's probably an optimization I can to fix that for the Yamaha preset. It comes down to poor pad construction, but can be compensated for in my scanning algorithm.
That is what I guess, after finding this:
https://www.2box-forum.com/index.php?topic=1010.0
If it's only the resistors in the piezo circuit that could be my saturday-afternoon-soldering-session. Is it?
Greetings
Manuel
The problem is that the lemon pads don't have a whole lot of mass, and so vibrate a lot which can stimulate the switch a tiny bit even when hitting the bow.
The same problem occurs with Roland CY-5 cymbals. I've implemented a fix for that for the piezo switch pad type, bit it's not implemented for Yamaha pad types.
We can test a fix when I'm closer to completing the next version.
Ah, ok, I got some huge, heavy washers, that I stuck onto to bottom of the 15" Lemon.
I thought that these high velocities originates from other vibrations.
So I will stick a few onto the bottom of the 18" ride, too?!
I will give that a try!
I talked to the guys from Lemon. They say:
"In the modul one can adjust the sensitity."
Err.... it's switch!
Sat Jan 08, 2022 3:13 am
That are great news! Thanks a lot!
Hi Rob!
But: I connected the unused cymbal output with edge_SW straight to the ring to an oscilloscope and left the cable to edrumin10 input plugged in
(piezo, bell, edge+10k). I can see wonderfull signals looking like a discharging capacitor when hitting the edge or choking. But not when striking the bow very hard. :?:
Simultanously, the edrumin control software showed up with an edge trigger when the scope showed the a flatline.
That means, mechanically the switch doesn't close.
