[WTS] Edrumin 10 and Edrumin 4
Looking to buy or sell used gear? Post here.
bandit614
Post by bandit614 »
I purchased these two units and I used them together.
It is important to note, the host port on the Edrumin10 has a BROKEN USB receptacle as described in this thread. viewtopic.php?f=33&t=1706&p=11966#p11966
It still works and it worked perfectly for me for daily use since April, but I have it duct taped together.
Rob has stated this can be fixed. I can also try to fix it myself as I have small electronic repair and soldering experience, but if you dont NEED this port or you're okay with duct taping the units together... this is the Edrumin10 for you
The Edrumin4 is in perfect condition otherwise with no issues!
Shipping from New York, paypal goods and services only
I will separate these due to the host port issue
Tjlw
Re: [WTS] Edrumin 10 and Edrumin 4
Post by Tjlw »
Sent PM.
Edit: PM appears to be stuck in my outbox.
