Missing HiHat hits
thenewdrummer
Missing HiHat hits
Post by thenewdrummer »
I have a Alesis Nitro HH foot pedal and the Alesis cymbal.
With edrumin the range of the pedal is really better, but I found that when I change the foot position sometimes the first 1-3 hits are lost. (I don't see them in edrumin either) and after that it starts to hit again.
If I stay always at the same foot position, there's never missing hit.
Is there a setting I could use to fix it ?
Re: Missing HiHat hits
You probably have the hihat xTalk control set too high.
I had this issue and lowering the cross talk (on the hi-hat pedal page) fixed it as Rob recommends
Can confirm that the crosstalk settings are really, really sensitive, and not just on the hihat. I was having issues with a CY-14 crash cymbal triggering erratically, and I was ready to take it apart to see what the problem was until I remembered I had set the crosstalk to 24 — waaaay more than needed. I reset it back to the default 15 and the issue went away. Just another little thing to keep in mind when dialing in your settings.
thenewdrummer
Rob wrote:You probably have the hihat xTalk control set too high.
Thanks it fixed my problem.
It was at 50 and I had to place it to something like 5.
Just for personal information, why crosstalk on the pedal? I understand on a pad or cymbal. How vibration can go in the pedal?
Is it because it takes control of the hihat cymbals? I understand maybe for impact mode?
Closing the pedal with a hi-hat mounted on a normal stand will trigger the cymbal pad. Pedal crosstalk cancellation ensures the foot 'chick' sound is triggered and ignores the pad vibration.
Impact is the mode for the 2 hat style (VH13) but the stand mounted controller (VH11 / Goedrum) is classed as 'pedal' as the information sent to eDRUMin is the same type as a pedal.
You're right that a pedal controller with an isolated hi-hat pad is already immune to pedal crosstalk.
The hi-hat pad crosstalk is incase the snare or cymbal share the same mounting arm (for example).
thenewdrummer
I see, thanks for the explanation.
monospace wrote:
Wed Oct 14, 2020 12:15 am
I think you left it at 24 in your CY-14 preset... So I was seeing missing hits on my hihat until I saw that... back to 15 and it's all good
Not sure if 15 is still the default but I'm using 7-8 now on all triggers that share a rack and that works fine too.
