Fantom crash sound.
BobBob
Fantom crash sound.
Post by BobBob »
I am using an alesis nitro mesh surge kit with an A2E snare with the help of jobeky trigger and SSD5.5 on Reaper.
While playing on the ride, a 10" Alesis cymbals, a full blast crash sounds occurs. And since I am learning a soft song, that's a hell of scare.
I don't know where it comes from.
It happens rarely so I can't pinpoint what could be the culprit, the cymbals, the edrumin, Reaper, the cables.
Is there a way to record Edrumin behavior so I can eventually save the data whenever it happens again and play it back to see what entry was triggered ?
Do you have another lead to identify the problem?
I
Re: Fantom crash sound.
It's really hard to say where the issue is coming from based on your description. The eDRUMin MIDI Monitor might help. That has a 1000 event memory and also shows the source of events (which input generated them(. If you go that route, I would have it filter CC messages to make it easier to find source of the problem.
