Hotspot not detected
thenewdrummer
Re: Hotspot not detected
Post by thenewdrummer »
Rob wrote:And the horizontal section is the minimum velocity (of the head piezo) required to trigger a rimshot. If you find that the rimshot is triggered when hitting just the rim of the pad, increasing that horizontal bar can fix that.
Good,
I'll be able to adjust it, thanks.
