Lemon 18" ride problem
Re: Lemon 18" ride problem
Can you get you to capture some data from your pad.
1. Connect your Lemon using just one input, without the Yamaha Adapter but keep your cable inside the tube.
2. Select its input in the eDRUMin control application.
3. Right-click on the eDRUMin logo 5 times and the left click on it once.
4. Click the the record button that will appear just above the velocity curve control.
5. Hit the bow of your pad as many times as it takes to get 3 mistriggers, leaving about a quarter of a second between hits.
6. Click the record button again to stop capturing data.
7. Email the the file ED_Data.hex that will appear on your desktop to support at audiofront dot net.
I a have possible solution for filtering out your mistriggers. Looking forward to getting the data from you. Might even be able to get that Yamaha adapter playing nicely as well.
fg61
Post by fg61 »
Thanks Rob for your effort, it's really kind of you and your support is unbelievable!
I definitely will capture the data you requested but it will likely be done on Saturday or Sunday when I will have time to do it.
To tell the truth I can now live with my setup but of course it would be way better to have the Lemon work as problem-free as possible even in Yamaha mode... :-)
So thanks again!
