Snapshot loading and midi assingments
CodaClef
Post by CodaClef »
I am setting up a new SD3 preset and was hoping to have an ED snapshot I could save and load with new MIDI assignments.
I saved out my current ED preset and created a duplicate, renamed it and started to change midi assignments.
I tried re-loading the ALT preset I had saved to make sure it was saving the settings and it does not re-load the midi assignments I had saved it with. It keeps the ones I had changed.
I am loading it by dragging it to the window.
Is this a bug? Am I doing something wrong?
Thanks!
Re: Snapshot loading and midi assingments
CodaClef wrote:
Tue Apr 08, 2025 12:03 am
Hun?
eDRUMin - Preset Manager
A concise overview of the eDRUMin Preset Manager.
CodaClef
Post by CodaClef »
Tue Apr 08, 2025 12:16 am
Hun?
This is the issue I am having:
2025-04-07 18-17-01
This is "2025-04-07 18-17-01" by Emile Smith on Vimeo, the home for high quality videos and the people who love them.
The load midi notes, velocities etc, never shows up??
You should be saving/loading device snapshots not drum maps. You can save a device snapshot by opening the preset manager and then clicking on the icon for you device.
CodaClef
Post by CodaClef »
Tue Apr 08, 2025 2:40 am
OK, missed th4e part of clicking on the edrumin icon then creating and saving kits.
I just created a new preset, thinking it saved everything from both of my edrumins but it looks like it only saved one?
Did I just lose all my settings when I loaded it???
Yes, it only saves/loads the settings for individual devices. And yes, you may have lost the settings for the other unit if you loaded the wrong device snapshot to it.
BTW, if you just want note assignments, you can adjust the load options so that only the note assignments are loaded--handy if you make changes to your trigger settings in the future and don't want to lose them.
Snapshot load options
