Hi-Hat question?
Hi-Hat question?
eDrumin update 2.4.0.1
DIY low volume cymbals, Metal dual zone pad type. Using mylar edge strip from Goedrum. used successfully on 2 and 3-zone cymbals.
- When the hats are closed, and striking the hats, would I get the bow or edge detected? I currently getting edge.
I guess my question when is the bow and edge detected?
Re: Hi-Hat question?
When the mylar strip has pressure on it, you will get the edge articulation. Sounds like it's working as expected (unfortunately).
