I added a bass drum kit piece, that shows on page 2 of the kit piece UI. It has the same note as the main bass drum though so I can't adjust them separately in my VST or DAW. I tried all the available drum maps - they all have the same note for my 2 bass triggers. Which note should I use and is there a standard way people are dealing with this?
thanks
Second Bass Drum Note - same as the first
Re: Second Bass Drum Note - same as the first
That's because none of the drum maps actually define a second base note. Page two is just there if you are going to create your own drum apps.. In fact I think to avoid any confusion, I will make page 2 hidden for the factory drum maps in the next version.
What you need to do is the the pad to use Custom Notes. I'm out for lunch so I can't send you a link to the section in that manual, but I can tell you it's mentioned in the Getting Started section.
I was aware of the Custom Notes, but wasn't sure if there was a dedicated way or not.
I will read up and get this sorted.
thanks Rob!
thanks Rob!
