Hello!
I'm a very satisfied user of midi drumin modules.
For a project I'm using a 4 input version . I use it to produce custom notes. It works very well exept for the C-2 note wich never produce the OFF message (it produce midi note ON but never the OFF).
This is the case for all inputs, as soon as I want to produce a C-2 whatever the input n° on the module the note OFF never arrives.
Am I missing something?
Thank you for you're help!!!
cheers!
Note C-2 never produce Note OFF
Re: Note C-2 never produce Note OFF
I'm pretty sure that bug was fixed some time ago. What firmware version are you using?
thank you for your answer.
My unit is up to date Firmware 2.3.1.32
and edrumin version 2.3.1 build 32
Look like this issue hasn't been resolved because I still present in version 2.3.2. I'll get it for the next build. Thanks for reporting.
UPDATE: Fixed for the next build.
OK Thank YOU.
