Preferred connection to computer
N2theSon
Post by N2theSon »
When using in conjunction with a module, is there benefit of one connection method below over the other?
eDrumming midi out --> module midi in --> module USB midi out --> computer
eDruming and module both USB midi out --> computer
Re: Preferred connection to computer
What eDRUMin are you asking about?
N2theSon
Post by N2theSon »
Sorry for lack of detail. I will be using an ED4. BTW...it is wonderful to see a developer so involved in a forum.
For an eDRUMin 4, I would just connect each device to your computer with the USB connection. Most drumming applications will allow you to select more than one USB MIDI device as MDII input.
N2theSon
Post by N2theSon »
Gotcha. That's what I suspected. Thanks so much.
Jazzmads
Post by Jazzmads »
Hi
I have same question, but I have a drumlin 10 and a drumlin 4. Is it still the same answer.
Best regards
Flemming
You should probably connect the ED4 to the Host port of the ED10 and connect the ED10 to your computer.
